2012-2013 BOSS 302
RAM Clutch + Boss = Fail
Old Jul 9, 2012 | 12:05 PM
OLOABoss's Avatar
PSA
As I jumped in front of the Bus to try to cure the Hot Transmission balky shift which I feel was the OEM clutch not fully releasing at high RPM when HOT on the Track. We installed a RAM Dual Disc 10.5" organic clutch with AL Flywheel as a unit from RAM. THe up shot of this experiment was the RAM clutch would not re-engage at shifts over 6500 until the RPM dropped to around 6000. RAM did accept the defective unit for a refund which is the correct thing for them to do. THe purpose of this post is not to dis RAM but inform Boss owners who might be thinking about an aftermarket clutch.
Peter
Old Jul 9, 2012 | 12:42 PM
CaptDistraction's Avatar
While not a boss, I ran a Mcleod RXT clutch on my 2011GT that we were revving sky-high. Once the switch was made to that clutch, there were no more engagement problems. Still some issues with gear lockout, but I'm running the stock shifter assembly, and you can feel the gates move when hot on a roadcourse. Need to at least try a shifter mount next.
Old Jul 9, 2012 | 02:24 PM
OLOABoss's Avatar
Its not the Boss per say as you said it is RPM related. Yes the shifter could be better but I wasn't going to keep the car if I can't shift it.
Peter
Old Jul 10, 2012 | 12:57 PM
thevidon's Avatar
Get the MGW and be done with it. It's worth the money.
May 3, 2026 05:42 AM
Gill5oh
Oct 6, 2017 10:50 PM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
