2012-2013 BOSS 302
LS Oil pressure sensor
Old Jun 8, 2011 | 12:31 AM
fred944's Avatar
I got the aeroforce interceptor w oil pressure sensor, but no Boss to put it in for a couple more weeks. I was thinking the LS might show me a good place to install the sensor. Have any of you seen where it is on the LS? Picture of the area around the oil filter would be great...
Old Jun 8, 2011 | 09:25 AM
5 DOT 0's Avatar
Which sensor did you buy? Do you have a link? I've also been looking at that gauge and the Roush vent mount.
Old Jun 8, 2011 | 09:51 AM
cloud9's Avatar
Very interested in this as well. I have the Aeroforce gauge in my A/C pod to primarily keep an eye on ECT, but would like to add the oil pressure sensor. Did you get the oil temp sensor as well?
Old Jun 8, 2011 | 10:44 AM
PTRocks's Avatar
This is what one of the prototype LS cars used.
Old Jun 8, 2011 | 12:03 PM
cloud9's Avatar
Is that tapped into the oil pan?
Old Jun 8, 2011 | 12:26 PM
06GT's Avatar
looks like a port in the block, to me
Old Jun 8, 2011 | 04:55 PM
PTRocks's Avatar
No high pressure oil passages in the oil pan. I believe the smooth black surface to the left is the back side of the alternator.
According to what I see on the Ford parts web site, it screws into the oil filter adapter, which is actually a plate mounted to the side of the engine block.
Old Jun 8, 2011 | 07:32 PM
fred944's Avatar
I ordered the temp sensor too, but it didn't come in yet. Here's where i got the stuffhttp://http://www.lethalperformance....53_10912_10930
PTRocks - thanks for the pic. I hope there are a couple unused ports into the oil system..
Old Jun 8, 2011 | 07:38 PM
5 DOT 0's Avatar
http://www.lethalperformance.com/201...633b3d120638dd
Old Jun 9, 2011 | 09:32 AM
cloud9's Avatar
Me too......up for info on this. Bought mine at Lethal as well.
Old Jun 9, 2011 | 10:25 AM
2012YellowBoss's Avatar
I guess I need a lot more seat time, right now I find it super hard to even look at the speedo for a second out there let alone read a oil pressure
Old Jun 9, 2011 | 10:36 AM
cloud9's Avatar
One of the nice things about the Aeroforce gauge is you can set up what they call the "annunciator". It will flash two red lights when you exceed or drop below a certain parameter. e.g. I have my ECT set to go off above 240 degress. You can also use it as a shift light and set if for a certain RPM. It will allow you to program two parameters. You'll get used to scanning your gauges when in the straightaways after a little more seat time.
Old Jun 9, 2011 | 01:25 PM
06GT's Avatar
Yeah you can ignore the speedometer...just focus on checking the system gauges on the main straight to make sure everything is OK with the car.
trackpack13gt
Jul 25, 2017 05:29 PM
southern stang
Sep 26, 2015 04:19 PM
