Help: interior light won't go off?!?!
Included of pic of where I mean. The light inside the car won't turn off when it's on. Turns off when I turn the car off. And yes I'm not retarded I have hit the buttons that turn them on and off. Are there any other buttons or something that could be causing these to stay on?
GeminiRising (10/14/20)
1 Post
From the 12MY owner's guide, see third bullet. Might check that one.
"Dome/Map lamps
The dome lamp lights when:.
• any door is opened.
• any of the remote entry controls
are pressed and the ignition is
off.
• the instrument panel dimmer
switch is rotated up, past the
detent, until the courtesy lamps
come on.
The map lamps are activated by
pressing the controls on either side of the lamp."
"Dome/Map lamps
off.
come on.
I bet it'll be the instrument panel dimmer............it's the thumbwheel to the by the headlamp switch.
If you wind it all the way up so that your instrument lights are at their brightest setting, the interior lights will stay on. Not sure what the maximum time is, but I've made this mistake and the lights were still on after 30 mins!
Wind the thumbwheel back down to about half way, then the interior lights will go out after a few seconds.
Yeah, I panicked when I first did this
The following 2 users liked this post by Twin Turbo:
GeminiRising (10/14/20),
Mr. Schoenherr (11/4/19)
Ive done it too detailing my car. I didnt even realize what i did wrong. When nightime came i just covered em with my sunvisors then about a week and a half later after not figuring it out i pushed/turned every **** or wheel or button in the car then i got it. One of my proudest moments ever
Thanks for highlighting it though. Sometimes we forget the simplest solution and make things harder than they need to be.
The Analog Admin!
Received 3,157 Likes
Welcome Ron Tee!
KC
KC
infinityonhigh
5/29/15 09:26 PM
