2012-2013 BOSS 302
Dead Battery Options
Old Mar 11, 2016 | 04:43 AM
SINBUSTER007's Avatar
so i think my battery in the boss has seen its days. ive had to charge it the last 3 times i tried to start the car (car has been sitting over winter since Oct).
i know in my 05-09 it was the same battery as what is in the boss but have seen on the forums to upgrade to the bxt-40r (to replace the bxt-96r).
i will probably keep the original battery just for keepsake with the car but has anyone else upgraded the battery or just bought the same stock battery that came with it?
i will also be buying a trickle charger over the weekend also to hopefully take care of this situation in future years.
thanks,
Old Mar 11, 2016 | 08:45 AM
karman's Avatar
Yes, get a trickle charger
Even with a good battery, you should either use a trickle charger or disconnect it if you are not running it every couple of weeks or so.
My 2006 came with a bxt-40r, which still holds a good charge 10 years later.
That doesn't mean that EVERY bxt-40r with do that on every car.
Batteries are always hit or miss.
I vote for getting a battery that looks like it belongs with the car and has a good warranty.
Old Mar 26, 2016 | 09:11 AM
TMSBOSS's Avatar
Yes. A trickle charger pays for itself. A battery which simply sits will discharge and then degrade to the point if being garbage. Battery Minder, Battery Tender are two systems I have used with good results.
Old Jun 29, 2016 | 12:14 PM
Official NOCO's Avatar
Like the posters above have stated, it is always a good idea to get a battery charger. Your battery will drain very quickly, especially in winter climates.
Old Aug 12, 2016 | 11:22 PM
Dayve's Avatar
Any good replacement batteries? I usually go to Sears for my Truck battery, but wondering if I should get one at Ford this time? Did not last too long, only 25k plus....
Dave
Old Aug 14, 2016 | 05:56 PM
Dayve's Avatar
Boss would not start, so I ended up picking up a decent battery at Auto Zone and putting it in myself. They only had one battery to choose from, that would fit.
Dave
TMS Editor
GT350
Jul 24, 2016 07:33 PM
Fords4Ever
16
May 2, 2016 06:02 PM
RoushRS3
Mar 15, 2016 09:54 AM
