Cylinder misfires
Cylinder misfires
Hey All,
I have 2013 Boss 302 that currently has just over 4000 miles and has been kept in great condition.
I have had it out regularly this summer, but today when I went out it went into limp mode while flashing the check engine light and wouldnt let me make any power.
I only got a few hundred feet from my driveway so i got back home without trouble.
Upon arrival, i hooked up my dtc scanner and found that i had 5 powertrain codes:
I inspected the engine bay and it wasnt excessively hot, i couldnt see any fuel/oil/coolant leaking anywhere, and from the wiring visible without any hardware removal noted that everything looked to be fine.
Any advice is appreciated. This is a car that my father passed unto me early this year when he passed and im pretty upset to see it having trouble given the care thats been shown to it so far.
Thanks!
-Gage
- random misfire
- cyl. 1 misfire
- cyl. 2 misfire
- cyl. 3 misfire
- cyl. 4 misfire
Thanks!
-Gage
I also had/have the same problem. Mine has 24k on it all original. I had the fuel system flushed. I replaced all the spark plugs and coils this winter. I had no problems until I had it at the shore and then a solid red light came on. My code was cylinder 4 misfire. I had the codes cleared and the light hasn't come back on. I'm taking it on a couple of long drives here in early August and we will see. Keep me informed if you come across anything else. And I will do the same with you.
Bryan Parks
May 28, 2016 12:42 PM
chief_charlie
2012-2013 BOSS 302
60
Nov 28, 2012 10:56 AM
