Brake upgrades for the track after reviews
#581
Brembo GT Brake upgrade?
Anyone tried this or any thoughts as to improved stopping performance in extended tracking conditions? Floating rotors are 15" rather than 14", 6 piston monoblock calipers.
#582
Sounds like the new GT500 system. Unfortunately for Ford, they didn't put in any ducting, and used a weak street pad, and have therefore seen multiple magazine articles about how the car is not up to track use (more than 1-2 laps) and will get trounced by the weak ZL1. If they'd just put in Boss ducting and used a decent pad, results would have been much better.
Other options for 6 pistons:
StopTech
http://www.brothersperformance.com/p...-6-piston.aspx
Actual GT500 units, no discs:
http://www.ebay.com/itm/2013-Shelby-...sories&vxp=mtr
StopTech
#583
StopTech
StopTech
I think the choice to go with what they did was based on the fact that a limited number of owners track the car, and those that do will probably go with a pad specific to track use, instead of something that would be mediocre at both. At the price point the car sits at with the packs added, most people shouldn't have a problem spending a few $$$ on dedicated track pads and rotors.
#584
Would go with the Stoptech system long before the Brembo just for the rotors. Not a fan of drilled rotors and don't know many guys that are. Ordered a set of two piece and they sent me drilled and slotted rotors after I specified I only wanted slotted. Had a few issues initially and can see already they are wearing poorly ----- as hot as I get the rotors I imagine there will be cracks soon. The slotted Stoptech rotors are killer if you are buying a package. There are a few others that are quite good, and if you can get a Brembo system with slotted only , it would then be an alternative.
Pad wise, Carbotechs have served me very well ,with 8s in the back. Normally recommend 12s in the front, but I am pretty aggressive and went with 20s at the last event. They definitely held up strong!
#585
I went with Carbotech's RP2's for the fronts, OEM still pads in the rears
then Carbotech street pad for the street
......this way I dont have to "prep" the rotor for their track pad
http://www.ctbrakes.com/pads.asp
#586
Does anyone even offer ducting for them? On a Track Pack GT500, would you have clearance for ducting through the fascia, or could you add some type of undercar diffuser to extract air and funnel it to the front?
#587
If I tracked it, I'd pull the fog lights, put in ducts there. Have a similar setup on my PJ/Heritage Saleen front fascia now and it works great, big 4" intakes.
But probably the aux radiators go through there. Maybe through the lower radiator opening, the sides there?
#588
StopTech
StopTech
After further review, Ford Press Kit says 15", Ford Sales Brochure says 14".
M3hunter
9/10/15 09:26 AM
