2012-2013 BOSS 302
Anyone changing the Boss 302 graphics . . .
Old 10/4/11, 04:58 PM
  #41
boss man's Avatar
Location: NJ. Waiting for our Gov. to be held accountable for his actions>>>Jersey Broke
Originally Posted by 06GT
I think you confused me with the thread starter
You are correct. So Sorry! I did confuse you with the thread srtarter. Thats because all of the graphics were removed and everyone looks the same....LOL
Old 10/4/11, 05:42 PM
  #42
06GT's Avatar
Still got my stripes, they're not leaving the vehicle anytime soon!
Old 10/4/11, 11:09 PM
  #43
Tob*'s Avatar
Originally Posted by boss man
Do the guys that wear stripes behind bars doing 20 years to life have CHARACTER?
If you remove the graphics from any model Mustang they will just all look alike. How many different colors and wheels can there be. graphics are good. it gives you the freedom to express your Mustang in any way you choose and can be changed form time to time and very little cost compared to paint. I myself want my Mustang to stand apart from someone else's Mustang. I have no problem with zit faced teeny boppers slobbering all over themselfs wishing they owned it (LOL....Sorry). As for the Law Man he to can enjoy looking at the car. it sounds like you like to have just a little to much fun on the street and feel the need not to draw attenision. Your Kona Blue Stang will look like any other Kona Blue Stang. Good luck to you on your quest to go un-noticed.
You've mistaken my quest for someone else's...
http://www.svtperformance.com/forums...pes-gt500.html
The zit faces won't know what hit them.
Old 10/5/11, 10:42 AM
  #44
06GT's Avatar
Interesting...in for video clips.
Old 10/5/11, 03:43 PM
  #45
Tob*'s Avatar
I hope any of you Boss owners can help me out here. I laid under my GT500 and mocked up fitment of the "quad pipes" in the general area where they will eventually reside. I noticed a couple of things immediately...
1) The plastic rock deflectors that are located just before the gas tank are in the way. From the best I can tell, Ford simply eliminated them on the Boss. Interesting if I'm correct, as I would have thought convection from the quad pipes could raise fuel temps a bit. Is there no deflector at all and/or are the fuel lines wrapped or protected in any way where the quad pipes run underneath them?
2) Where the polished exit is bolted to the chassis at the rocker...I'm well aware of the hardware shown used on the pipe (the windshield wiper grommet and bolt) but I can't tell what is in use on the body. Is there a nut welded somewhere inside the rocker (or near the rocker) or is it attached to the underside face of the floorpan. I can't find any closeups of it on the web, just shots that capture the pipe exit (and not the hardware at the body). Any photos would help me out here - bigtime.
Here's a shot where you can see some of the hardware but not all of it at the quad exit...
On edit....here's a better shot. It almost looks as though the tip exit connection point has the rubber grommet tight to the floorpan. If so, I'd assume there is a hole (similar to the unused threaded hole before the large oblong hole) with a nut inside and above it, yes?
It definitely looks as though the deflectors are omitted on the Boss, but I do see what I think are the brake cables and they look insulated...
Old 10/5/11, 04:37 PM
  #46
2012YellowBoss's Avatar
Here is another picture if you can blow it up, not the best and pic I know but I could try to get another pic later (not today)
https://themustangsource.com/f813/an...5/#post6079958
You can see the same bolt in your picture also. I do not know if the nut is welded in place but I suspect so, just never looked that close. It is in the rocker and I do not think it goes through the floor pan, it looks like it has a box like structure added to hold the nut. You can see that in the pic I posted, see if you have that first and then if you still need more photos let me know.
Old 10/5/11, 04:46 PM
  #47
Tob*'s Avatar
This one?
It does look like a nut. I'll have to see if '12 GT500 chassis' have that nut or if it was Boss specific...
Old 10/5/11, 06:04 PM
  #48
This one?
I just looked at mine and it is different then the one in that picture so disregard what I wrote. It looks to be a a rounded tube tapped out vs. a "standard" nut and it is up inside the inner part of the rocker panel. I guess it is welded there and that may be very hard to copy. You will need to figure out a way to get a nut up inside there, there is a hole in front of it. If you can not weld it in place I would think a lock washer would do the trick.
On the other hand a setup like the one pictured may work, just don't know if it would be too low. (nut welded below the rocker)
To get a better picture I need to take the rocker bolt out. I can try to get a pic soon if no one else has one handy.
Old 10/5/11, 06:44 PM
  #49
Tob*'s Avatar
Scott, I'd appreciate it if you could get a shot but maybe you wouldn't have to....
Let me ask. Is the "nut above the sheetmetal" done the same way as the one situated on the other side of the oblong hole? Does the rubber grommet seat against the sheetmetal, unlike what the above photo shows?
Old 10/5/11, 08:39 PM
  #50
Before I say something for sure let me un-bolt it to make certain. The PP car in the pic looks like the just welded a nut below the sheet metal of the rocker, mine (looked real quick) looks like the "nut" is above the sheet metal of the rocker. The grommet looks to be pressed against the sheet metal. However not sure what you mean by
Old 10/5/11, 08:52 PM
  #51
Tob*'s Avatar
I'll get a shot of the area on my '09 and post it up tomorrow for clarification.
Thanks for your help.
Old 10/5/11, 11:38 PM
  #52
06GT's Avatar
hang on I'll go jack mine up...
Old 10/5/11, 11:59 PM
  #53
06GT's Avatar
There is a nut welded inside the chassis on both holes fore and aft of the oblong hole. Not sure what the thread on the front one is, but the one for the side pipe takes an M15 socket. There is no additional spacer, just the rubber grommet.
Old 10/6/11, 12:03 AM
  #54
black_bullitt's Avatar
Without reading the last several posts, I'll assume this thread has, like most others in this section, gone off track. Why else would there be undercarriage pics in a thread about stripes/graphics?
Old 10/6/11, 12:45 AM
  #55
06GT's Avatar
Don't ask me man, I'm just posting pics
Old 10/6/11, 04:16 AM
  #56
Tob*'s Avatar
Drew, huge help. I'll assume the oblong hole to be in the same spot on the earlier '07-'09 chassis. What would you say the distance was between hole centerlines, an inch to an inch and a half?
And offtrack? This isn't an Obama redirect, etc, it is an extension of "making changes" to our beloved S197 chassis vehicles. Huge help from you guys and it is much appreciated.
Old 10/6/11, 06:54 AM
  #57
06GT's Avatar
Tob I didn't take a good look at the hole positioning but I believe that both holes are the same distance from the oblong hole. Does your car have either of the F/R holes?
I believe the oblong hole is likely used for chassis positioning during movement at AAI, so probably in the same place for all S197s.
Old 10/6/11, 07:30 AM
  #58
Tob*'s Avatar
Your logic mirrors the assumption I had in mind regarding the oblong hole and AAI.
Off the top of my head I believe I have the forward hole. I'll check it out after work today. You've been a great help. Thank you.
Old 10/6/11, 05:57 PM
  #59
Tob*'s Avatar
Drats. No hole fore or aft.
If you get bored Drew, could you give me a dimension from the oblong hole (1-1/4" would be my guess from the closest edge of the oblong hole).
I figure I can drill a hole where I need it, then insert a nut with an integral washer upside down into the hole and then weld around the perimeter of the washer.
On edit...what is really odd is that I found a thread where a guy in Europe says his Boss was delivered with one of the quad pipes damaged. His photos seem to depict a nut on the surface of the floorpan, like the display car at Woodward (third photo)...
Weird.
Old 10/6/11, 08:40 PM
  #60
06GT's Avatar
Yeah ill get some measurements later tonight for you
Edit: The battery for the digital readout on my calipers is dead, but looks like 1.125" from edge of the oblong hole to C/L of the threaded hole, or about 1.75" center of threaded hole to midpoint of oblong hole.
Just to be sure you might want to install the new pipe setup, and put a thick dab of paint on the top of the sidepipe bolt, then just touch the bolt to the chassis as it would sit. Boom, instant marking.
Raynier Leonardo
'10-14 Exterior Modifications
27
3/2/17 12:08 AM
southern stang
9/26/15 04:19 PM
Quick Reply: Anyone changing the Boss 302 graphics . . .
