2012-2013 BOSS 302
Any new recomends on tires?
Old 6/19/12 | 09:24 AM
5 DOT 0's Avatar
Originally Posted by JPC
anyone tried the Nitto Invo
.......on on Boss? ......or anything else?
I'm sure they are fine for the street but you should aim higher for track use. The Yokohama AD08's or Michelin PSS's are going to be the hot setup for street tires in close to stock sizes. Both of those tires run a 5% lower aspect ratio which is probably a good thing for the track and 295 in the rear. The Michelin's are supposed to be better in the wet.
Old 6/19/12 | 01:09 PM
2006mach1's Avatar
Originally Posted by Fenderaddict2
Hot I was running 40/41. Had to inflate them to 36/34 for that outcome. Hot day and my driving was rusty. Going to try 35/35 at TMS next with bars set 4/3 front/rear and see how that goes.
Thanks.
Last time I ran TMS, I beleive I had my shocks set at 5F, 4R with the stock Perrilli tires at 41 lbs. Let me know when you go to TMS, I might be able to meet you up there.
Old 9/7/12 | 10:12 AM
JPC's Avatar
JPC
Originally Posted by nota4re
For primarily street driving, it is really hard to beat the Hankook Ventus V12 mentioned above. A VERY good tire for the money. Available in stock sizes.
For a track tire, we've been using the Yokohama AD08 in the following sizes;
265/35-19 in the front and;
295/30-19 in the rears
This is a very good track tire that will give you about 85% of the "stick" as a Hoosier but will last at least 2-3 times as long as the Hoosier.
Any pictures with 265-35 and 295-30 on stock OEM Boss rims?
Old 9/7/12 | 11:49 AM
JPC's Avatar
JPC
I was research more this AM:
I found these Nitto INVO's 285-35-19 all around/square $266/ea 260aa
Anyone running 285-35-19 all around?
Old 9/19/12 | 08:00 AM
JPC's Avatar
JPC
Anyone track a Boss on Nitto NT05 275-40-18 square setup?
opinions?
Old 9/19/12 | 10:26 AM
SoCalBoss302's Avatar
Im going to try the Mickey Thompson Street Comp. There is a post on the main page about them. They seem like a good option to for track and the price is not too crazy. Im still going to look for more reviews but leaning that way.
Old 9/19/12 | 11:04 AM
JPC's Avatar
JPC
I read somewhere this AM, the new MT tires are made by Cooper
http://www.moddedmustangs.com/forums...per-rs3-s.html
and in the video they show a COOPER tent..
.....why would COOPER tent/rep be at a MT track test
Old 9/19/12 | 11:27 AM
Renesis05's Avatar
I'm using Bridgestone RE-11's. 265/35/19 in front and 285/35/19 in back. The front's are about 0.6 inch shorter than the stock Pzero's but look fine. These tires have significantly more grip than the Pzero's. The forward traction improvement is profound.
Old 9/19/12 | 12:19 PM
thevidon's Avatar
The new MT's appear to be just a copy of the Cooper Zeon RS3's:
Cooper tread:
MT Tread:
Given the incredible similarity here in tread and cost plus the fact that Cooper owns MT you can probably draw the same conclusion I did.......
Old 9/19/12 | 03:15 PM
Resolution78's Avatar
Makes sense maybe tweaked alittle
Old 9/19/12 | 04:51 PM
UOP Shadow's Avatar
There's a lot more to a tire than just the tread pattern. Could be different carcass construction as well as different rubber compounds. Even though they look the same, they can perform completely differently!
Old 9/20/12 | 08:29 AM
thevidon's Avatar
Originally Posted by UOP Shadow
There's a lot more to a tire than just the tread pattern. Could be different carcass construction as well as different rubber compounds. Even though the look the same, they can perform completely differently!
I was hoping the compound would be different but given that the costs are virtually identical I am doubtful. Heres to hoping I'm wrong!
Old 9/20/12 | 09:00 AM
JPC's Avatar
JPC
Mich Super Sports @ 275-35-19 all around?
I heard all good things about the new PSS
DiscTire has them @ $337/ea
and IF you get them square u get a 30k mile warranty (different front/rear is only 15k)
http://www.discounttire.com/dtcs/infoTireMath.dos
the sizes difference is not too bad
thoughts?
Old 9/20/12 | 08:36 PM
mtnbikefuel80's Avatar
thoughts?
M4A1 said he likes them in this thread. I will soon be ordering these tires as well in 275/35 R19 all around for my car (PZeros just hit 10k miles two days of AutoX at the end of the month at Daytona should get them pretty close to gone. I need a second set of wheels and tires lol). They scored well on the Tirerack Test as well. I saw them at $316 plus a $80 rebate a month and a half ago, I should have ordered them then. Oh well.
Old 9/21/12 | 12:26 PM
gr8pmknboss's Avatar
opinions?
I run the Nitto NT-05 275-40-18's on a set of 18x10 SVE Drift wheels on my BOSS when I put it on the track. I have had good luck with the tires and they seem to grip quite well. A fair bit better than the stock 19"
Old 9/21/12 | 03:13 PM
phiggs54's Avatar
Where do you track? I've been to Grandsport in Hitchcock 3 times, not far from you. Going out Oct 28th. Would love to see another Boss out there.
Old 9/22/12 | 03:30 PM
Brandon302's Avatar
Hopefully I won't be the first to ask this, but what are you guys (if any) running for winter/all season for when it gets colder? Decided to buy a Boss for a daily/track car so I am trying to find something that will work for daily driving in the cold and will get some track rims and tires at some point. Currently I have looked at Kumho Ecsta 4x for all seasons but they only make a size big enough for the front.
Old 9/25/12 | 05:59 PM
Roamer's Avatar
I changed to Bridgestone S-04's, and found them to be less harsh, less road noise, and better when caught in the rain. I'm saving the Pirelli's for track use when I have more time for weekend fun.
Old 10/2/12 | 10:44 AM
JPC's Avatar
JPC
Installed new Mich Pilot Super Sports this AM
255-40-19 fronts
275-40-19 rears (no 285-35's)
Pictures of the rears:
(yes I know will wash the car later today)
Attached Thumbnails Any new recomends on tires?-tire-1.jpg   Any new recomends on tires?-tire-2.jpg   Any new recomends on tires?-tire-3.jpg   Any new recomends on tires?-tire-4.jpg
Old 10/7/12 | 06:06 PM
  #40
galaxieman's Avatar
I just had the Michelins put on my 12 GT Coupe last week. P Zeros were trash in 27K miles strictly street. Noisy and rough riding. I hope the Michelins are as good as on previous sedans I owned.
cozyp828
4/18/16 09:46 PM
10/2/15 01:00 PM
Quick Reply: Any new recomends on tires?
