New Magnetic door guard in stock.
Supporting Vendor
We now have the magnetic door guard in stock at Amazon and www.zl1addons.com they are made to use in your own garage or parking space.
__________________
John www.zl1addons.com
Supporting Vendor
I do not have a video
__________________
The circle is loading something and I'm not going to waste my time or bandwidth. Open with a simple jpg or never mind. Believe it or not the world is not on unlimited cable bandwidth.
But thanks for editing and posting a pic on post 1.
the pad seems like a good idea as I stated, but I would like to understand how these points might be able to be addressed?
Supporting Vendor
They are not made to use in a public parking lot. we make them to use in your garage or parking space to keep the car next to it from dinging the door. you can use more than one if you need it. On our site we explain that you use it in your garage or parking spot. You could use it in a public space, but you would never know how a door lines up, but you will know in your own garage. My two cars are hard to get in with out touching when door is open.
__________________
as I said its a great idea and im not knocking it by far (and may even buy a few) but even the truck and Mustang I drive I don't park them in the same exact position every time, at times the mustang might sit further back (towards the street) in the drive way then the truck, or reverse of that.
also just out of curosity (trying to satisfy the engineer side of me) is there any dats on the type of material use? is it rubber or metal? I also note your pad uses "rare earth metals" I am assuming its some sort of Neodymium magnet? if not do you have the type listed? reason I am curious is I am wanting to know if this is a metal pad while it may protect my Mustang lets say whats to prevent the pad from inadvertently causing a scratch to the other car door that bumps into the pad or hits it with some force (someone opening the door and not knowing how close there car was next to it)?
again please don't take my criticism or questions as a negative look on the product, I am looking at this from a computer/it engineers prospective that thinks about this type of stuff on a constant basis!!
Well in a garage for example. 2 cars could be very close. Growing up this was the case in our two car garage. Typically in a garage, people use some sort of mark where they pull in the exact same each time. So it would well in this scenario.
Regarding the magnets. What is protecting them from scratching or dinging your car when you add and remove it?
