Sponsored by:
Sponsored by: CARiD
will Ford drop the MT82? please!
Old Mar 30, 2013 | 08:10 PM
  #41
Tony Alonso's Avatar
Originally Posted by db2797
Ok so the driveshaft isn't the SOLE reason the clunk exists. But it doesn't appear that the engineer your copying the post from is completely discounting that the driveshaft could also contribute in some manner.
Not trying to be argumentative here with this question - in what manner do you think it would contribute?
And with regards to the original topic, I sincerely hope that a redesign of a remote shifter mechanism is done or the transmission updated to eliminate the need for the remote set-up.
Old Mar 31, 2013 | 01:14 AM
  #42
V10KLZZ71S's Avatar
MT82 is the smoothest trans I have ever used. Idiots are what they should eliminate.
Old Apr 1, 2013 | 04:03 PM
  #43
Sieran's Avatar
My VW GTI shifted WAY smoother than this transmission... even the 6-speed POS in my '07 Wrangler shifted smoother.
Not saying this one is bad or i don't have confidence in it, just saying it is not smooth by any stretch of the imagination... unless you are shifting over 4K RPM then it is smooth as butter (except that stupid 2-3 shift).
Old Apr 1, 2013 | 08:33 PM
  #44
grabberblue 5.0's Avatar
I own an 11 and I've year driven a '13, they have done something different with the 13+ to make the trans wayyyyyy more smooth. I remember something like phosphate coated gears maybe? Either way, you're correct the the 2013+ mustang GT's are far smoother with a lighter clutch as well. But the 11-12's seems to be the troublesome ones
Old Apr 2, 2013 | 08:37 AM
  #45
V10KLZZ71S's Avatar
I believe the playskool quality shifter is the biggest problem. Especially when the engine is twisting under power. My MGW shifter has been my best mod yet, even topping my engine mods. I think I read the 13's have a different fluid which helped.
Old Apr 2, 2013 | 06:38 PM
  #46
97GT12's Avatar
Originally Posted by grabberblue 5.0
Maybe if it was just a couple of people complaining I would agree, but there a re numerous people that does not like the stock shifter for most of the same reason, the fact that it does not easily go into gear and that it's often hard to find the gears.
Maybe a little pilot error, but in this case a lot of ford fail too
I still feel that the way the ratios are spec'd out confused numerous people given the large number of complaints on downshifting. Many IMO were simply selecting the wrong gear ratio. They were using the same gear number that they would use for a typical mustang 5spd, but the MT-82 is set up with first being an extra gear. Thus, 2nd is like first in a T-45, 3rd is like 2nd and so forth. Someone who didn't try to figure out the car but instead forced it, could very likely cause damage. It would at the very least explain why downshifts couldn't be accomplished because it was too severe of a speed difference.
Ecostang
Nov 3, 2022 08:50 PM
JonathonK
GT350
Sep 17, 2015 10:13 AM
unnoticedtrails
V6 Performance Mods
20
Aug 18, 2015 03:11 PM
trackpack13gt
Aug 8, 2015 11:23 AM
Kgilly
Jul 9, 2015 01:47 PM
