Tire size info.
275/35-19s should be real nice for all 'round setup. Most kits for this size wheel use this size of tire.
You could also do staggered at 285/35 in the back, and 255/40 in the front, but be aware that rotation is definitely not happening, and the handling will be different.
Just keep in mind that a 275/35-19 has a diameter that is .5" smaller while a 275/40-19 has a diameter .6" larger than the stock diamter. Personally I would go with the 40 series to fill up the wheel well more.
There are 17, 18, 19 and 20" wheel options on the S550 Mustang. All have tire size that gives you a 27.1" overall diameter with the exception of the GT Performance Package rear tire which is slightly larger in diameter. The two 19" sizes are 255/40-19 and 275/40-19 (rear of GT PP).
Then I would go with all 275/40-19s and be done with it. They'll rotate and be correct diameter. Sure, you don't have the staggered handling/look, but if rotation is a thing (which it is with me) then that's what I'd be doin'.
Can't be havin' no 255s in the back on those rims, c'mon, maaan...
Can't be havin' no 255s in the back on those rims, c'mon, maaan...![Big Grin](https://themustangsource.com/forums/images/smilies/biggrin.gif)
Feffman
11/3/15 04:54 AM
