Sponsored by:
Sponsored by: CARiD
Tire size info.
Old Nov 8, 2015 | 01:02 AM
Bruthnlaw's Avatar
Tire size info.
I just purchased a set of 19x9" wheels and need to know what size tire I can run on front of my 15 GT premium , can someone help in this matter.
Old Nov 8, 2015 | 05:10 PM
houtex's Avatar
275/35-19s should be real nice for all 'round setup. Most kits for this size wheel use this size of tire.
You could also do staggered at 285/35 in the back, and 255/40 in the front, but be aware that rotation is definitely not happening, and the handling will be different.
Old Nov 8, 2015 | 07:15 PM
Bruthnlaw's Avatar
Yep want to be able to rotate will go same on all four corners , but I do like the look of the staggered wheels. Thanks for the info.
Old Nov 9, 2015 | 05:51 PM
dgc333's Avatar
Just keep in mind that a 275/35-19 has a diameter that is .5" smaller while a 275/40-19 has a diameter .6" larger than the stock diamter. Personally I would go with the 40 series to fill up the wheel well more.
Old Nov 9, 2015 | 11:28 PM
Bruthnlaw's Avatar
I appreciate the info. Now I need to find out what size would fit 19x9" wheels without running issues.
Old Nov 9, 2015 | 11:30 PM
Bruthnlaw's Avatar
Sorry rubbing issues, auto correct hate it.
Old Nov 10, 2015 | 10:36 AM
AWmustang's Avatar
Aren't there 19 inch options from the factory? Why not just go with that size?
Old Nov 11, 2015 | 05:47 PM
dgc333's Avatar
There are 17, 18, 19 and 20" wheel options on the S550 Mustang. All have tire size that gives you a 27.1" overall diameter with the exception of the GT Performance Package rear tire which is slightly larger in diameter. The two 19" sizes are 255/40-19 and 275/40-19 (rear of GT PP).
Old Nov 11, 2015 | 08:27 PM
houtex's Avatar
Then I would go with all 275/40-19s and be done with it. They'll rotate and be correct diameter. Sure, you don't have the staggered handling/look, but if rotation is a thing (which it is with me) then that's what I'd be doin'.
Can't be havin' no 255s in the back on those rims, c'mon, maaan...
Old Nov 13, 2015 | 08:26 AM
dgc333's Avatar
Unless your car came with 275/40-19's the speedo is going to be off a little (you will be going faster than it reads). Plus a 9" wide rim is the minimum rim width for a 275/40 tire. A 255/40 fits perfect on a 9" wide rim and will be the same diameter as the stock tires.
Old Nov 13, 2015 | 08:37 PM
houtex's Avatar
Oh yeah, well, there's that. My bad. Sorry about the speedo thing. I always forget that...
dave07
Jan 10, 2016 09:11 AM
Bert
Nov 11, 2015 08:43 AM
drumstix5001
Nov 7, 2015 01:23 PM
Feffman
Nov 3, 2015 04:54 AM
TMDM
Oct 20, 2015 12:36 AM
