Sponsored by:
Sponsored by: CARiD
Steeda S550 Differential Bushing Inserts - Urethane and Aluminum - Now Available!
Old May 22, 2015 | 04:25 PM
tj@steeda's Avatar
Hi everyone,
Our engineering team has been hard at work developing new upgrades for your S550, and we're really excited about our two innovative differential bushing inserts!:
Steeda S550 Mustang Adjustable Differential Bushing Insert System - Urethane (2015 All)
Steeda S550 Mustang Race Differential Bushing Insert System - Aluminum (2015 All)
Steeda S550 Mustang Differential Bushing Insert System - Street to Full Race Combo Kit (2015 All)
Adjustable Differential Bushing Insert System - Urethane 555-4439, $99.95:
When our engineers sat down to design this kit, we had to come up with a way to increase performance without sacrificing an ounce of drivability, all while keeping the car quiet.
Unlike our competitors' kits that will absolutely increase NVH (noise, vibration, harshness), take 3-4 hours to install and force you to permanently modify the rear IRS suspension with a sawzall, Steeda’s does not! Our kit installs in under 1 hour, adds ZERO increase in NVH, is adjustable and can be easily removed - it simply doesn’t get any better than this!
Minimize pinion angle changes, increase traction, eliminate wheel hop and differential deflection with Steeda's new kit. Made from high-strength urethane to our exact specifications and durometers, our kit comes with 2 different bushing options - red 'street' 80 durometer bushings and our black 'performance' 90 durometer bushings. Both bushing options will increase performance with no increase in NVH, a Steeda-exclusive.
Steeda’s kit adds the strength and support the OEM bushings need to perform the way our customers intended. Once again, this is not a permanent modification - there is no drilling, cutting or pressing required. Simply loosen and remove a couple bolts and this kit installs in less than 1 hour. Bushings are included for both the front and rear differential mounting locations in addition to grade 10.9 hardware with zinc-plated washers.
Race Differential Bushing Insert System - Aluminum 555-4440, $94.95:
We also knew we needed a kit for the hardcore racers out there! Made in-house from billet 6061 aluminum, this is not a permanent modification - there is no drilling, cutting or pressing required. Simply loosen and remove a couple bolts and this kit installs in less than 1 hour. Aluminum bushings are included for both the front and rear differential mounting locations in addition to grade 10.9 hardware with zinc-plated washers.
Please note: This is a race-only part. It will increase NVH and gear noise.
Steeda S550 Mustang Differential Bushing Insert System - Street to Full Race Combo Kit 555-4442, $169.95:
For those of you that would like a complete one-stop shop street to full race kit which provides interchangeability options for both urethane and aluminum bushing inserts, we have the perfect combo kit. For the small amount more the Steeda kit will cost you, you will be saving so much more on labor (over 3 hours) when comparing to competitors' kits. Here's a link to our combo kit 555-4442.
Video Comparison:
Here at Steeda, we welcome competition. Why? Because it continually pushes us to be better and ultimately provide the best end-product for you our customers.
Best Regards,
TJ
Old May 27, 2015 | 02:46 PM
airborne0416's Avatar
nice
Does your company provide a military , forum or multiple item discount? Been snooping around your products and there are a few items I would like to install all at once . thanks
Old May 27, 2015 | 07:51 PM
tj@steeda's Avatar
Yes, I will p.m. you with the details.
Best Regards,
TJ
Rando
Aug 25, 2021 11:12 AM
Sep 30, 2015 07:02 PM
Sep 24, 2015 08:15 PM
