Sponsored by:
Sponsored by: CARiD
TPMS Variations
Old May 7, 2015 | 08:21 AM
Salguod's Avatar
TPMS Variations
I did not see a thread dedicated to the several varieties of TPMS that exist, so I thought I would start one and try to get some input from everyone.
For background, I ordered a staggered set of FRPP Laguna Seca wheels (M-1007KIT-DC19910LGB which includes 4 TPMS) and Michelin Pilot Alpin PA4 N-Spec (265/40R19 - 4 tires) winter tires for my new Mustang. When I receive the wheels, I will mount the Michelins on the black PP wheels and store them for winter use at Discount Tires for $75, and mount the staggered Pirellis on the FRPP wheels for the summer.
Before I got my car, I also bought 4 2015 Mustang TPMS (F2GT-1A180-AB/F2GT-1A150-AB) from CJPony who said they will definitely fit my 2015 Mustang.
After I got the car, I checked with Forts Parts at the local Ford dealer, who looked up my VIN and said my car takes the F2GZ-1A189-A TPMS. These are backordered till June 1st.
Prior to posting this thread, I found a number of references to using older TPMS on 2015 Mustangs which worked fine. I do not believe I saw one instance where an earlier TPMS was found to NOT work.
When I receive the new wheels, I will have them assembled with tires and TPMS at Discount who has done a good job for our family in the past.
Does anyone know if you can test a TPMS before it is mounted? Can you test one wheel/tire/TPMS assembly before you install all of them?
The goal is to get a set of working TPMS from the get-go, without having to re-install anything.
I would greatly appreciate your input, comments and suggestions.
Old May 8, 2015 | 12:24 PM
Salguod's Avatar
Has anyone had any experience with new wheels and new TPMS on 2015 Mustangs?
Old May 8, 2015 | 04:47 PM
yugoboss's Avatar
I used the f2GT-1A180-AB in my 2015 F-150 They are also called tpms 35. They should work as long as they are 315mhz
Old May 8, 2015 | 07:22 PM
Salguod's Avatar
Thanks for your reply, Yugo. Do you know if Ford uses the same system on all platforms? I have a set of those same TPMS, so that would be cool.
Old May 28, 2015 | 10:09 AM
Salguod's Avatar
Update: I installed the new wheels with the CJPony TPMS and everything worked fine, so I believe a variety of TPMS would work. As long as they are the right frequency.
trackpack13gt
Jul 25, 2017 05:29 PM
trackpack13gt
Jul 23, 2015 11:13 PM
