Sponsored by:
Sponsored by: CARiD
SPARE TIRE FOR GT WITH PP
Old Dec 16, 2014 | 05:35 PM
guitar's Avatar
I would like a spare tire for a '15 GT with the PP pkge. Driving without a spare won't work for me and the Tire Mobility Kit provided as a replacement does not make sense to me. Run flat tires (although I am not a fan) would be better! Perhaps someone from Ford might have a solution?
Old Dec 16, 2014 | 05:54 PM
2snake's Avatar
I Agree.. I want the PP also.. But I need spare tire also
Old Dec 16, 2014 | 08:10 PM
SD CALSPCL's Avatar
Check with your parts department. There is a spare tire kit available. I ordered mine the day I picked up the car. It was $250.00, includes the hardware to install, the tire and jack. Here is a photo of the spare installed in the trunk. If you get a flat on the rear, You may have to put the spare on a front wheel and move the front wheel to the rear due to the limited slip diff. something to check with your parts/service guys.
Old Dec 16, 2014 | 08:17 PM
SD CALSPCL's Avatar
Deleted double post
Old Dec 16, 2014 | 08:22 PM
Cobrakev's Avatar
That spare will not fit on the PP Mustang. Wont fit over the brakes.
Old Dec 16, 2014 | 08:25 PM
SD CALSPCL's Avatar
Thanks for correcting me. I did not know that.
Old Dec 16, 2014 | 11:43 PM
It will fit over the rear...
Old Dec 17, 2014 | 12:00 AM
berzerk_1980's Avatar
Verified by both of us on the '14s. Are they the same rear brakes on the 2015? If so, seconded.
Old Dec 17, 2014 | 01:05 AM
Rears are the same on all the 2015s, as far as I know?
Old Dec 17, 2014 | 03:45 AM
Cobrakev's Avatar
With the 9.5" rim and a 275 tire on the back, I don't know if it will fit on the front. The PP has staggered rims.
Old Dec 18, 2014 | 05:44 AM
bob's Avatar
bob
Is the spare the same diameter as the PP wheels? If its smaller in diameter it will cause a difference in speed across the axle and there in might be the problem with only being able to run a spare on the rear.
I'm not sure how a Torsen diff reacts to a constant difference in speed across the axle but on the older clutch type limited slip diffs it would cause them to wear out prematurely and when running a spare on a vehicle that allowed the spare to go in any position it was best to put the spare on the front and rotate the proper size tire to the rear.
Ford may have other reasons for not equipping the PP cars with a spare.
Old Dec 21, 2014 | 05:44 AM
Anthony k's Avatar
There is a guy that had his car delivered with 9.5" wheels and 275's all around.
Error on the assembly line
So, they fit
Old Dec 21, 2014 | 06:38 AM
guitar's Avatar
Originally Posted by Anthony k
There is a guy that had his car delivered with 9.5" wheels and 275's all around. Error on the assembly line So, they fit
Not sure what you mean. I think all 4 wheels (both sizes) will fit on the front (Brembo brakes being the main issue). Turning circle might be reduced?
Old Dec 21, 2014 | 10:45 AM
Lucky guy haha
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
