2014 and older rims fit 2015?
Old 4/26/16, 08:29 PM
emba129's Avatar
Hi folks. I am looking to get a set of winter wheels for my 2015 GT with 19" 50th anniversary wheels. I am considering a set of 2014 or older 18" rims, 5 spoke OEM mustang rims that are easy to clean. Question is will these older rims fit the 2015, larger 14mm stud and is the bolt pattern the same?
Old 4/26/16, 10:47 PM
Mrbobcat's Avatar
Don't quote me but I think they would fit. I got some 2011 wheels to use in the winter for my 2014.
Old 4/27/16, 10:22 AM
emba129's Avatar
2015 went to 14mm lug studs. Not sure if 2014 or prior wheels will fit over those studs. I think they are all 1/2" or 12.7mm Anyone try it on their 15 or 16?
Old 4/27/16, 10:43 AM
RonStang65's Avatar
If you want low cost OEM 18" wheels take a look at these http://www.newtakeoff.com/single_201...num_wheel.aspx. Although you can probably find less expensive aftermarket wheels.
Old 4/28/16, 11:45 AM
Mrbobcat's Avatar
Really? If so, that's something else to consider since I have a extra good set of snow tires and rims that fit the 2014. Also have another set from my gencoupe that I can't seem to sell.
Old 4/29/16, 08:57 AM
shouldhavegottheGT's Avatar
S197 wheels will fit no problem. I put my wheels and spacers from my 13 on my 16. Just needed different lug nuts.
Knight721 (11/17/18)
GoSpeedGo
5/4/16 03:55 AM
JonsMustang
4/27/16 10:26 AM
GrabberBlue14
4/4/16 03:21 AM
canadian_pony
3/29/16 09:20 AM
Quick Reply: 2014 and older rims fit 2015?
