Sponsored by:
Sponsored by: CARiD
2014 and older rims fit 2015?
Old Apr 26, 2016 | 08:29 PM
emba129's Avatar
Hi folks. I am looking to get a set of winter wheels for my 2015 GT with 19" 50th anniversary wheels. I am considering a set of 2014 or older 18" rims, 5 spoke OEM mustang rims that are easy to clean. Question is will these older rims fit the 2015, larger 14mm stud and is the bolt pattern the same?
Old Apr 26, 2016 | 10:47 PM
Mrbobcat's Avatar
Don't quote me but I think they would fit. I got some 2011 wheels to use in the winter for my 2014.
Old Apr 27, 2016 | 10:22 AM
emba129's Avatar
2015 went to 14mm lug studs. Not sure if 2014 or prior wheels will fit over those studs. I think they are all 1/2" or 12.7mm Anyone try it on their 15 or 16?
Old Apr 27, 2016 | 10:43 AM
RonStang65's Avatar
If you want low cost OEM 18" wheels take a look at these http://www.newtakeoff.com/single_201...num_wheel.aspx. Although you can probably find less expensive aftermarket wheels.
Old Apr 28, 2016 | 11:45 AM
Mrbobcat's Avatar
Really? If so, that's something else to consider since I have a extra good set of snow tires and rims that fit the 2014. Also have another set from my gencoupe that I can't seem to sell.
Old Apr 29, 2016 | 08:57 AM
shouldhavegottheGT's Avatar
S197 wheels will fit no problem. I put my wheels and spacers from my 13 on my 16. Just needed different lug nuts.
GoSpeedGo
May 4, 2016 03:55 AM
JonsMustang
'10-14 Exterior Modifications
14
Apr 27, 2016 10:26 AM
GrabberBlue14
Apr 4, 2016 03:21 AM
canadian_pony
Mar 29, 2016 09:20 AM
