2014 and older rims fit 2015?
Hi folks. I am looking to get a set of winter wheels for my 2015 GT with 19" 50th anniversary wheels. I am considering a set of 2014 or older 18" rims, 5 spoke OEM mustang rims that are easy to clean. Question is will these older rims fit the 2015, larger 14mm stud and is the bolt pattern the same?
Don't quote me but I think they would fit. I got some 2011 wheels to use in the winter for my 2014.
2015 went to 14mm lug studs. Not sure if 2014 or prior wheels will fit over those studs. I think they are all 1/2" or 12.7mm Anyone try it on their 15 or 16?
If you want low cost OEM 18" wheels take a look at these http://www.newtakeoff.com/single_201...num_wheel.aspx. Although you can probably find less expensive aftermarket wheels.
Originally Posted by emba129
(Post 6978952)
S197 wheels will fit no problem. I put my wheels and spacers from my 13 on my 16. Just needed different lug nuts.
