Won’t shift
Old Aug 12, 2024 | 06:34 PM
Nuclearwolf's Avatar
Won’t shift
Replaced the the clutch with a new one. Got the hole kit slave cylinder master cylinder bearing new line all the good stuff. Whenever i try to shift gears while pressing in the brakes, it like hitting a wall or if i have it in gear and try to take it out i have to yank it out or turn the car off first.
Old Aug 12, 2024 | 07:33 PM
05stangkc's Avatar
Welcome,
What Year Stang?
What Engine?
What Exactly Did You Use To Repair Clutch? Factory Ford or Aftermarket. Can You Supply Part Numbers?
What Exactly Failed on Original Clutch.
Did You Scan For Any DTC Codes??
Kc
Old Aug 12, 2024 | 09:54 PM
Welcome,
What Year Stang?
What Engine?
Kc
2011
5.0
M-PACT 07199WS
clutch was getting spongy and car was jerking when taking off from 1st gear
Only codes that are showing is o2
Old Aug 13, 2024 | 02:53 AM
05stangkc's Avatar
Alright I Have Pulled Some 2011 Mustang 5.0L Ford Shop Manual Pdf's, Some Maybe Helpful. Take Note of Misfire Monitor Needing to Be Reset as Directed End of Clutch Install Pdf. I Have Enclosed The Section on it as Well! The Diag Pdf Should Be a Good One To Check Out!
Best Of Luck!
Kc
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 13, 2024 | 06:05 AM
Bert's Avatar
welcome to the forum
Originally Posted by Nuclearwolf
.... Whenever i try to shift gears while pressing in the brakes, it like hitting a wall ....
don't hit the brakes while you shift
Npropst23
Jun 16, 2015 06:44 PM
Valnar300
1994-2004 V-8
Sep 24, 2014 11:41 PM
airoscar
Jul 12, 2012 11:07 AM
mtnbikefuel80
Jul 5, 2011 05:02 PM
deshawnb50
May 28, 2011 09:27 AM
