Power Steering Fluid Noise from Dash
Old Dec 16, 2012 | 10:09 PM
kylerohde's Avatar
Now that it's a little colder, I'm noticing this noise more than in the past - I'm pretty sure it's power steering fluid flowing but I've never driven a car where I could audibly hear it before. Nothing seems wrong with the car so maybe it's normal - anybody else noticed this sound?
Old Dec 16, 2012 | 10:15 PM
TheReaper's Avatar
Your car doesn't use power steering fluid. It has EPAS.
Old Dec 17, 2012 | 05:45 AM
Bucko's Avatar
From Wikipedia:
Electric power steering (EPS or EPAS) uses an electric motor to assist the driver of a vehicle. Sensors detect the position and torque of the steering column, and a computer module applies assistive torque via the motor, which connects to either the steering gear or steering column. This allows varying amounts of assistance to be applied depending on driving conditions. Engineers can therefore tailor steering-gear response to variable-rate and variable-damping suspension systems, optimizing ride, handling, and steering for each vehicle. In the event of component failure that fails to provide assistance, a mechanical linkage such as a rack and pinion serves as a back-up in a manner similar to that of hydraulic systems.
Electric systems have an advantage in fuel efficiency because there is no belt-driven hydraulic pump constantly running, whether assistance is required or not, and this is a major reason for their introduction. Another major advantage is the elimination of a belt-driven engine accessory, and several high-pressure hydraulic hoses between the hydraulic pump, mounted on the engine, and the steering gear, mounted on the chassis. This greatly simplifies manufacturing and maintenance. By incorporating electronic stability control electric power steering systems can instantly vary torque assist levels to aid the driver in corrective maneuvers
Old Dec 17, 2012 | 05:49 AM
shurtual86's Avatar
Originally Posted by Bucko
That's what I thought....electronic power assist steering now. No more power steering pumps in the engine bay.
My brother-in-law has a car with EPAS, and it makes some noise when it's cold (below 30 degree),
Old Dec 17, 2012 | 07:46 AM
kylerohde's Avatar
Duh. I knew that but hearing the fluid near the steering wheel made me forget. So what the heck is this fluid noise then?
Old Dec 17, 2012 | 01:32 PM
TheReaper's Avatar
I will be listening for this noise when the temperature drops.
Old Dec 17, 2012 | 08:37 PM
kylerohde's Avatar
Thanks man.
Old Dec 17, 2012 | 09:50 PM
SD CALSPCL's Avatar
Well, it has been pretty cold here, but I have never noticed the noise you are describing. However, have you tried cycling the heater on and off to see if the noise changes or stops. It is possible you are hearing fluid running through the heat exchanger for the heater. Why you would hear it and no one else seems to hear it in their cars, I can't answer. But, each car is different and will have it's own little quirks, this may just be yours.
Old Dec 18, 2012 | 12:20 AM
Xar's Avatar
Xar
it's been f'n cold here (snowing temp) and I don't hear nuthin but the 8 girls singing....
Old Dec 18, 2012 | 08:47 AM
kylerohde's Avatar
Dang, this is a weird one! It's going to the dealer on Thursday for an alignment and to take care of the 5K max oil life monitor TSB issue, so I'll ask them and let you guys know. It's gotta be something simple - everything on the car is working correctly.
Old Dec 18, 2012 | 09:18 AM
FordService's Avatar
Hey kylerohde,
I recommend you speak to your Ford dealer as soon as possible. Your service manager will be in the best position to assist you with this. Keep me posted on what happens.
Deysha
Old Dec 21, 2012 | 08:18 AM
TheReaper's Avatar
It's 29 degrees this morning and no noise from the steering.
Old Dec 23, 2012 | 07:43 AM
825LTRGT's Avatar
My Milan DD had the same issue. In this case it was coolant flowing in the heater core. There was some air in it.
Ford replaced the water pump. It stopped after that.
Not apples to apples but it may help.
Old Dec 28, 2012 | 08:55 AM
kylerohde's Avatar
Thanks man - the water pump has already been replaced in this car once under warranty, will ask the dealer about it next time I'm in there.
Old Dec 28, 2012 | 09:24 PM
B-Fox's Avatar
Make sure to lift the hood and check your coolant level. However, since the cooling system has been serviced it's possible you have an air pocket trapped in the heater core, the best way to get rid of it would be by draining and refilling the system with an "airlift" or "radkit" which pulls a vacuum on the cooling system, then the cooling system will pull the coolant back into itself and eliminate air pockets
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
ricky1728
Feb 11, 2016 07:25 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
