Hood corrosion
#41
All true. However, it at least shows the problem is fairly widespread and kills the argument I've seen a lot of guys say they ran into of "this is a unique problem."
#42
My 2006 has a small spot on the passenger side under the lip. The paint had a small crack in it so I tried to seal it with touch-up paint I have. The spot is spreading ever so slowly.
#43
http://avstop.com/ac/apgeneral/corro...numalloys.html
http://www.aviationpros.com/article/...ting-corrosion
Fighting corrosion
Once corrosion has been detected, treatment is a must. In some cases, the damage is superficial enough to be removed, and then for the repaired area to be protected with anti-corrosion products. In others, corroded components may have to be removed and replaced.
Traditionally, technicians have employed wax, oil, and paint in such areas; treatments that are both messy and have to be removed before future inspections can be done. In contrast, newer products such as NO COR are clean, transparent, and do not have to be removed for further inspections. Other anti-corrosion products of note include Corrosion Technologies’ CorrosionX Aviation spray penetrant, which can be sprayed over existing corrosion to displace moisture and prevent the further migration of electrons; and Granitize Aviation’s Xzilon 3AECI Aircraft Exterior Corrosion Inhibitor, which prevents oxidation on exterior paint and bright work.
#44
The current Ford Warranty Guide even explicitly states aluminum corrosion is covered for 5 years:
Originally Posted by Page 11, 2016 Ford Warranty Guide
If aluminum body panels have corrosion or rust damage, and the damage is not the result of abnormal usage, vehicle accident, customer actions and/or extreme environmental conditions, the corrosion or rust damage repairs are covered for 5 years, unlimited miles.
I'm going to bring it up again at my dealer next week when I go in for the airbag recall. I don't expect to get any satisfaction though, they've been completely unhelpful on this issue so far. It's entirely disappointing; the front of my <60k Mustang looks like a 12-year old Hyundai hooptie, AND it's all because of a known and acknowledged material/manufacturing defect, but Ford still won't stand behind their **** and do what's right.
#45
Bumping an old thread, I know, but this is such BS...
I get the Ford can change their warranty terms over time, but it's pretty clear that they intended for aluminum panel corrosion to be included in the 5-year corrosion coverage, not just the 3-year BtB coverage. All these cars, up to and including 2016s are subject to the same problem, referenced in the same TSB (16-0028). Logically, the warranty coverage should be fair and equal too.
#46
I just think it's sad that Ford knows this is a problem, to the point of issuing a TSB and adding language to their warranty SPECIFICALLY addressing the fault, all while their dealers weasel out of covering it.
The new warranty makes it pretty **** clear Ford intended the fault be covered by the corrosion warranty. The dealers just didn't/won't do it.
#47
Oh believe me, I know. Just to clarify; I own a 2013, and my dealer's been telling me it's not covered for a year now, ever since I noticed it.
#49
Originally Posted by JG1
I just noticed the edge of my hood starting to bubble. I guess I'm ****ed because I have a 2012 GT and it's out of warranty.
Bull****.
Bull****.
GKosovan (5/12/19)
#51
Legacy Tms Member
Waiting for my new hood to arrive. Last fall the hood bubbles starting forming on the front of the hood. I'd rather spend money on mods that make me go faster, but I can't live with a hood that will looks like crap.
#53
#58
Is there any reason to keep my stock hood or should I just trash it?
Originally Posted by 2k7gtcs
I hung mine up in the garage as wall art
