Hood corrosion
Old Aug 11, 2016 | 12:47 AM
DrVet's Avatar
Hood corrosion
Have a 2014 convertible. I've read many posts about the hood corrosion issues. So far I don't see it on mine. Is it a foregone conclusion that all hoods will be affected? Or do some escape the issue?
Allen
Old Aug 11, 2016 | 05:22 AM
SpectreH's Avatar
Most escape the issue. I bought my '13 GT convertible in July 2012. So far, so good. (knock on wood)
Old Aug 11, 2016 | 09:33 AM
kylerohde's Avatar
Allen
That's a tough question to answer. There's a ton of anecdotal evidence on here that most of the cars have it, but it clearly wasn't a big enough problem overall for Ford to ever issue a TSB, a recall or change their process anytime during the 10 model years it's an issue (05-14).
All I can say is, check your car over meticulously before you hit the 3/36 warranty expiration. Ford will take care of it until that point and, after that, you're in for a pain in the butt fight that you'll likely lose.
Old Aug 11, 2016 | 10:34 AM
Getportfolio's Avatar
My 11 didn't have it but 12 did. Hit or miss.
Old Aug 14, 2016 | 10:16 PM
DrVet's Avatar
Just checked my hood and trunk lid closely. No issues yet.
Allen
Old Aug 16, 2016 | 12:12 PM
Dean Martin's Avatar
I'm two for two on an '05 and '12 both having it.
Old Aug 19, 2016 | 09:41 AM
mfc133's Avatar
There is a TSB now, it includes every Mustang built since 2005 plus many other Fords:
TSB 16-0028
Old Aug 19, 2016 | 11:57 AM
esir_spd's Avatar
TSB 16-0028
Well that's nice of Ford, a simple fix...
Old Aug 19, 2016 | 12:04 PM
mfc133's Avatar
Ford had been replacing the hoods outright (mine was replaced along with some other forum members), but now it looks like they're only repairing the existing panel.
Old Aug 19, 2016 | 04:34 PM
esir_spd's Avatar
I'm assuming that it will cost us if we are out of warranty though.
Old Aug 19, 2016 | 06:24 PM
kylerohde's Avatar
TSB 16-0028
Wow. Finally.
Not sure...I'm curious how this affects the way they deal with it though.
The body shop manager at my Ford dealer was adamant that an affected hood can't be repaired permanently. He would only guarantee that a new hood could be painted to avoid the problem ever happening again.
Old Aug 19, 2016 | 10:07 PM
berzerk_1980's Avatar
Wow. Finally.Not sure...I'm curious how this affects the way they deal with it though.The body shop manager at my Ford dealer was adamant that an affected hood can't be repaired permanently. He would only guarantee that a new hood could be painted to avoid the problem ever happening again.
Yeah, this is interesting and overwhelmingly what's being reported. However, both body shops I have used (for other repairs) insist that this is repairable by redoing the seam sealer.
One of the repairs included work to the hood. I mentioned the hood corrosion issue before they started work and they told me their work has a lifetime guarantee so don't worry about it. If it happens they'll redo the work.
Presuming they're good on their promise, the assurance is good enough for me... It's not that big a hassle.
Old Aug 20, 2016 | 04:28 PM
kylerohde's Avatar
Hey moderators, I think this one is worth sticking at the top of the page - there's been so many posts about this problem over the years and this TSB is the first official acknowledgement from Ford that there is indeed a problem. Lots of guys should have new ammo to use with their dealers and with Ford now. Just wish it'd come out before I replaced my hood completely with an aftermarket one, though it was free thanks to insurance (unrelated hail damage claim).
Old Aug 25, 2016 | 08:12 AM
VidPro's Avatar
Legacy Tms Member
My hood was repaired by a dealer shortly after I bought my 2014. No return and looks great. It's been about two years or so.
Old Sep 1, 2016 | 07:33 AM
oldnjguy's Avatar
Thank You for this information. Just saw a small area on front hood lip.
Old Oct 6, 2016 | 08:04 AM
13GetThere's Avatar
I too found a small area on the lip of my hood. I'm waiting to hear back from Ford.
Old Oct 6, 2016 | 08:32 PM
3point7's Avatar
I'm afraid that's incorrect my friend. TSB 16-0028
They have even gone ahead and included the 2016 Mustang because apparently they have just resigned themselves to the fact that they can't figure out how to assemble a car with aluminum body panels correctly.
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=193285
Old Oct 6, 2016 | 10:28 PM
kylerohde's Avatar
****. 2015-16 F-150 too.
Old Oct 6, 2016 | 11:37 PM
3point7's Avatar
Yep. I was skeptical about the all aluminum F150 from the beginning because you have an aluminum body with a steel frame and what causes the corrosion is dissimilar metals, i.e. steel and aluminum. So at some point the body has to be mounted on the frame and they have to use steel bolts I would assume. I can't imagine how they are going to avoid corrosion on that truck and given the Ford track record with aluminum panel corrosion I would think it's a forgone conclusion that the things are going to corrode.
Old Oct 7, 2016 | 09:19 AM
13GetThere's Avatar
How much does a GT hood weigh?
