Hood bubbling
#41
Painting the entire hood is the only RIGHT way to do it. Grabber Blue may or may not be hard to match, but chances are better it will match by painting the entire hood rather than trying to spot match. I would have been pissed if it were the other way around and Ford only wanted to spot repair the hood. You should be happy.
EDIT:
Called the shop they want to use and the owner is going to meet me at the dealer to inspect the paint bubble and tell me what he thinks they will need to do to fix it.
#42
OK just wanted to say that the autobody owner that I spoke with yesterday said the hood is toast. The issues with the hood are too close to the hard edge line for them to properly fix it without messing up the hood line. So now I need a new hood + paint job. Deysha I sent you a PM, may need your help with this after all.
#43
Deysha
#44
#45
#46
Deysha I sent you a PM with my VIN let me know that you got it and how to go forward from here
Too true and that is unacceptable, my only advice for those casually browsing this is check early and often. Every new mustang owner should check for this at vehicle pickup.
#47
Deysha
#48
I picked up my 2012 Boss 302 late at night on Mar 29th. Next morning I noticed bubbles under the paint on the rear deck lid lower edge. Took it to the dealer and they removed the bubbles and repainted the area. Looks good right now. I don't know what metals are used for the hood/ rear deck lid construction but the bubbling problems sound like a "dissimilar metal' corrosion issue. If aluminum and steel are in contact around the perimeter of the hood/deck lid there will definitely be what's called "galvanic" corrosion if moisture is introduced. Basically, the two different metals can set up a battery cell condition and start eating at the softest metal first. Exact same thing happened to patio storm doors on my home when the lower edge of the aluminum door was capped in a steel sill plate scraper. Took two years but the door started to corrode away very rapidly. I sent pics and my ideas on the problem to the manufacturer and they shipped me all new doors and components that were made of the same material. No further problems for the last 12 years. BTW, I was the corrosion control engineer/officer for a carrier based fighter squadron back in the early 70's. Just my opinion on this issue and maybe it will help solve the problems for the future.
#49
I just got back from a 2800 mile road trip to Key West and back, the size of the bubble on the front lip of the hood doubled in size in just a couple weeks, will be taking it to the dealer tomorrow to be stripped and repainted, my car has 63K miles on it now so paying half ($200) to fix the hood isn't that bad of a deal.
#50
if you guys are having hood corrosion issues, it might be caused by metal that's contaminated before it's painted... there's more info here about the issue: http://www.wexlerwallace.com/investi...investigation/ hope this helps!
#51
Oho. Intersesting. Check it:
http://www.google.com/search?sclient...31293566093510
Mustang isn't the only one... Thanks Jay. I had no idea.
/didn't look at it, so I didn't know.
//That... sucks.![Stick Out Tongue](https://themustangsource.com/forums/images/smilies/tongue.gif)
///kinda wondering if Jay isn't a spammer for the law firm, but hey, I'm ok with it JUST THIS ONCE.
//That... sucks.
![Nono](https://themustangsource.com/forums/images/smilies/nono.gif)
#52
![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
The good news is that it's so common you don't have to be embarressed
#53
Well that blows, thats why i took it to the dealer. There is no way I was paying out of pocket and end up having something like this happen. They should just go with an all aluminum construction for the hood or change out the unlike metals for a plastic. When I was talking to my service manager he told me this is an issue on a lot of cars.
#54
Just got my '12 GT on Thursday, 9/1, and noticed a similar problem on the under edge of my hood toward the front.
I was told that the problem was not rust but was a sloppy weld.
I did find similar areas on the under side of the trunk lid along with an area that was actually scratched down to the metal.
Notified the dealer two hours after taking delivery after finding the trunk lid damage.
If it's just cosmetic, don't know if I want them grinding on the original finish.
Also Grabber Blue btw
Opinions? Thanks!
Opinions? Thanks!
#55
Underside of hood right?
80 grit + Rust reformer + paint = problem gone.
I did this on my '08 last year and it has not come back yet. And I brushed the paint on.
It's not "Show quality" but the bubbling is gone and the dealer didn't screw up the top of the hood that everyone sees.
