Engine abruptly revving intermittently (2012, 6 cyl, 3.7L, automatic).
Old Mar 4, 2019 | 04:19 PM
MattJL's Avatar
Disclaimer: I'm asking on behalf of my mother, though I've seen this firsthand.
An intermittent issue has been plaguing the car in question for the last six months. Typically goes like this:
  • The rev counter will abruptly begin to climb, topping out at around 3k RPM.
  • The engine will start to sound as if it is accelerating, though the vehicle itself won't change its speed.
  • In conjunction with these two issues, the other gauges will flip back and forth wildly (though this didn't happen with the most recent occurrence).
  • The issue will wind down and cease after a short amount of time.
This tends to happen when the car accelerates from a stop, or while it's already at speed. Additionally, this happened before the cold weather set in, indicating that the problem isn't cold-related. Car's been through the dealer and two local mechanics, the latter of which are very highly-esteemed and generally good at diagnosing problems. Computer isn't throwing any errors, and because it's so intermittent (it's happened maybe 10 times within the last 6 months), it's been impossible to replicate. Terminals are clean, too, though the battery itself hasn't been replaced (to my knowledge).
I suspect that it may be the PCM/ECM, given that whatever's causing the problem appears to be non-mechanical, but I've also read that it might be the FSU. It's the most bizarre issue that I've ever seen and heard of. Seems strange that nobody has caught it up to this point. I'll try to be as helpful as I can.
EDIT: Forgot to add - car's got 80,000-ish miles on it and is a DD, regular maintenance, up to date on all recalls.
EDIT 4/2/2019: My reply to this thread got caught in moderator purgatory, so I want to add this up top for anyone else scurrying across the Internet in search of an answer. It's most likely the molded leadframe in the transmission. Look up recall # 16N02 - "Molded Leadframe Extended Coverage." We never got a recall notice mailed to our house, and I naturally concluded that this car was exempt from it. But as I did some digging, I found out that this car was built at the same plant, and during the same time as, the recall.
So if you're starting to deal with this failure, look up your VIN here: https://owner.ford.com/tools/account...e/recalls.html It's listed as an FSA (Field Service Action Item).
If it somehow turns out to not be the molded leadframe, then I'll scrub this edit, but after watching videos of other people with the same failure, I'm 80% sure this is it.
Thanks to everyone who replied. You've helped crack this case.
Old Mar 18, 2019 | 10:26 AM
Lime GT's Avatar
This is for a 2011 but may be the same as yours. Check these grounds in the engine compartment. http://iihs.net/fsm/?d=711&f=010%20-%20Grounds.pdf
You may find the locations here; http://iihs.net/fsm/?d=711&f=151%20-...on%20Views.pdf
Sometimes the painted surface under the ground terminal blocks continuity. I would remove the terminal and clean the paint only where the terminal sits and the re-tighten the connection. At the least, loosen and re-tighten the bolts clamping the terminals. This will give a new bite to the body panels and give you a chance to see if it corrects the problem.
Old Mar 18, 2019 | 12:02 PM
SpectreH's Avatar
My 5.0 at one time wanted to occasionally rev between 500-1500 RPMs. Cleaning the throttle body fixed the problem. The issue I had isn't exactly what you are describing, but it might be worth investigating.
Old Mar 18, 2019 | 01:23 PM
Bert's Avatar
  • The engine will start to sound as if it is accelerating, though the vehicle itself won't change its speed. . . . .
Assuming the car is in gear when this happens, the only way the engine RPM can increase but the car does not go any faster, is the clutch or transmission has to be slipping; or it is downshifting
any idea what is going on with the transmission when this happens?
MR-STANG
Mar 13, 2014 08:46 PM
VroomVroomVroom
Aug 14, 2013 08:57 AM
SoFlo Mustang
Apr 15, 2011 07:33 PM
atomicvibe
Nov 27, 2007 07:05 PM
thestanger
1994-2004 V-8
Oct 26, 2004 05:19 PM
