Driveline clunk
Old Apr 24, 2014 | 07:54 AM
stevew2023's Avatar
Driveline clunk
I have a 2013 V6 convertible, Auto trans, with 3.73's, CAI and Bama Tune. Since installing an Axle Exchange aluminum driveshaft I have a very bad clunk when putting into gear and when it downshifts from 2nd to 1st. It has become more than just annoying, I am concerned there is a problem or it is going to turn into a problem down the road. I called The Axle Exchange and was told #1: the hollow aluminum DS will resinate any driveline sounds, and #2: that there is a known problem with these transmissions and I should get it checked.
Has anyone else experienced this or any suggestions?
Steve
Old Apr 24, 2014 | 02:55 PM
Womprat's Avatar
IIRC the trans is the TR6060 6-speed, correct? I think thats a pretty stout transmission overall, but anything can fail. Are you lowered? A lowered car may need the pinion angle adjusted so the u-joints dont bind. Did they give you the correct length DS? Also check your control arms, are any bushings worn, or anything loose?
Old Apr 25, 2014 | 10:32 AM
stevew2023's Avatar
Not lowered and everything seems to check out ok.
JMU
Sep 27, 2015 07:53 AM
00StangVert
1994-2004 V-6
Sep 11, 2015 12:08 PM
dream2015
Aug 31, 2015 03:55 PM
Mackitude
Aug 17, 2015 04:14 PM
John H
Aug 8, 2015 04:58 PM
