Breather leak or twisted axle tube?
Old Mar 21, 2013 | 06:48 PM
mongooztt's Avatar
I have a '12 Brembo GT (purchased in May 2012) that just turned 4k and I completed the 1st oil change this weekend. While the car was up, I noticed the wet diff on the drivers side. A little searching turns up a TSB on the breather vent (drivers side axle tube). Does this look like an excessive amount of diff fluid to be coming out of the vent?
Or does this look like a twisted & leaking axle tube, I have never tracked this car or raced it in any form or fashion. Hell, it's just now broken in! I have yet to even witness the shift light flash. I'm going to take it to the dealer with the TSB in hand tomorrow, just wanted a little background knowledge because they are idiots.
Old Mar 21, 2013 | 07:22 PM
TwistedKarma's Avatar
Looks excessive. I had the same issue. I brought my car to a local dealership and they informed me of the TSB. They ended up replacing both the vent and tube. That's your best bet, good luck!
Old Mar 21, 2013 | 07:52 PM
14Glassback's Avatar
The carrier looks wet well above the axle tube. Would say it is likely the vent. Probably part of the TSB. I read about it too. And it is definitely excessive.
Old Mar 21, 2013 | 08:17 PM
mongooztt's Avatar
They replaced the axle tube or the vent tube? If it was the axle tube, it seems like it'd be cheap just to swap the whole housing.
Old Mar 22, 2013 | 01:46 AM
I look at the repair paperwork in the AM, I could be wrong.
Old Mar 27, 2013 | 01:07 PM
GBStang13's Avatar
My car had the same issue, the informed me of the TSB ( btw ) the original owner got this serviced. No leaks since.
Old Mar 30, 2013 | 08:31 AM
mongooztt's Avatar
I've determined that the vent is the issue. I weighed the pro/cons of having the TSB performed. The turkey baster vent might fix it, but I intend to eventually attend track events so I decided to install the GT500 finned cover, relocate the vent to the top of the diff, and fill with Royal purple 75w140. The cost of doing this is ~$140, which to me is less than the hassle dealing with a dealer...
Old Mar 30, 2013 | 08:55 AM
BRADGTCS's Avatar
this has been a fairly common issue with the new stangs. I had the same thing.
Old Apr 2, 2013 | 05:28 AM
Kgilly's Avatar
Just had my vent replaced this past weekend at the dealer during my annual inspection. They said the manufacturer sometimes does not put sealant around the threads on the vent tube when it is installed in the axle. So far so good.
2011 Premium GT, MT82, 400A, Airaid CAI, BMR Panhard Bar, GT500 axle-backs, JLT oil separator, side window louvers, 30% window tint.
Old Apr 7, 2013 | 08:46 AM
mongooztt's Avatar
This was not the case with mine. When I removed the vent to install the plug, there was plenty of yellow thread sealant on it. I relocated the vent to the port in the top of the GT500 cover.
Old Apr 11, 2013 | 08:16 AM
2012GTCS's Avatar
I had the TSB done and they put the Turkey baster on. Well the over axle pipe melted the whole top of it. So its probably sealed shut lol. Now I put on aftermarket OTA pipes so they will probably charge me for it.
Isn't there a new TSB without the Turkey baster style?
May 3, 2026 05:42 AM
Rando
Aug 25, 2021 11:12 AM
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 24, 2015 08:15 PM
