2013 mt82 Gt No Crank No Start
Old May 17, 2024 | 08:51 PM
holleywood's Avatar
So my car one morning would not start, when i turned the key, everything lit up just fine and normal, fuel pump engaged and everything, yet when i would try to turn it on, it would not crank, and wouldn’t start. I ran codes on it, and it came up with “invalid data from ecm/pcm - invalid serial data received” and another code “control module- system internal failure” i have checked the ecm connections, brand new battery, and everything else connection. the car was dyno tuned, yet i don’t have a tuner in the car itself. I am now lost. If anyone has had this problem, i am FULLY open to suggestions. Thanks!
Old May 17, 2024 | 09:20 PM
05stangkc's Avatar
Welcome.
If You Have Not Already a 15 Minute Battery Disconnect Would Not Hurt To Try!.
Check Through The 303-14 Section Post 1. It Maybe Helpful. Also PATS Section Post 3
https://themustangsource.com/forums/...e-info-550475/
Also I Would Check The SJB For Any Signs of Water Intrusion.
https://themustangsource.com/forums/...on-sjb-550481/
KC
Check Out The Module Overview the PDF!
Dleeuwendaal
1994-2004 V-8
Sep 7, 2023 01:32 PM
JT_Kwik
Nov 29, 2022 01:45 PM
Effektx
Apr 14, 2014 09:43 PM
Todd72
Feb 18, 2014 10:27 AM
