Electrical car cuts out.
So I forgot the ignition on overnight and battery drained all way down. Had to recharge then it ran for a number of weeks. I fear I burn some components. Need assistance it cuts out while driving then does not want to start for 5 min and then starts and will cut out again. Besides the constant control relay module. What else could be the problem?
So, I See From Your Profile You Have a 1995 Mustang GT. Since You Mention it Have You Replaced CCRM????
Have You Checked For Trouble Codes With a Scanner??
You Say It Cuts Out, When, All the Time or Only When Trying to Accelerate??
When It Won't Start For 5 Minutes Have You Checked During That Time For Spark or Fuel Pressure??
If it Ran Fine For A Couple of Weeks Before this Issue May Consider Bad Fuel, Plugged Fuel Filter or Unrelated Issue!
KC
KC
KC
KC
Mgb,
KC
