2013 headlight issue
Old Apr 26, 2013 | 09:08 PM
Tapakegovagnaps's Avatar
I'm having an issue where one of my headlights will switch back and forth between high and low beams. This is only when I have the high beams on. The problem light's projector has a noticeable film over it. When I look at the good headlight, the projector is clear. I know there is a loose connection, cause it will switch back and forth when I encounter bumps.
Part of me wants to take out the intake and take a look at it, but, I know I won't be able to clean the interior of the projector, so even if I do fix the erratic light, I still will have a slightly clouded projector. So I'd like ford to replace the housing/projector and whatever else is causing the issue.
Has anyone had anything similar occur?
I have not had a chance to take it in yet, and I'm not sure when I'll have the opportunity.
Old Apr 27, 2013 | 08:33 PM
mikeyt03's Avatar
I had the same problem. Ford told me it was a normal characteristic of the new 5.0 headlight. Then they tried to fill it with an oil additive.
Old Apr 28, 2013 | 09:54 AM
Go ahead, smoke another
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
JonsMustang
Mar 5, 2016 05:44 PM
DarrenGT
Sep 19, 2015 01:00 PM
Grabber5.00
Sep 13, 2015 06:53 AM
Linkspure
Sep 12, 2015 06:33 PM
