2012 AC Compressor Failure 40k
Old Apr 21, 2016 | 03:13 PM
Excelcius's Avatar
I have seen a few other threads detailing this issue but they are usually from a couple of years ago, but I was wondering, how many of you know about someone or have had your AC compressor fail and ruin your AC System? I drive a 2012 Boss 302 at 40k miles; my AC compressor destroyed itself as I drove down the road. The dealer quoted me $2,315 to repair and flush my system. My warranty has run out and no, I did not buy the extended warranty. I realize that this was a gamble, but I did not expect a repair equal to 8% of my car's value before 50k miles. I've seen other posts about this issue, and am surprised that this happens.
I called customer service and they will not help me with the repair because I bought the car second hand. Why did I do that? Because there were 11 Boss 302's sold in my state, and despite entering the dealership to buy a brand new GT in 2013, I saw that they had a 14k mile 2012 Boss 302 for sale. How could I pass that up? Well, as a result, I have no customer score with Ford, and they declined to assist me. The dealer here also refuses since I purchased it in a town I used to live in. I'm frustrated, but mainly I'm baffled that such a major thing could break at 40k.
TL;DR How many of you have had your AC compressors fail before 50k?
Links to other failures: (some links refuse to show as links but call themselves files for some reason)
No 1.
No 2.
No 3. 347773-2011-mustang-gt-air-conditioning-problems.html
No 4. 699873-2011-ac-compressor-gone-already.html
No 5.
No 6.
No 7. 882786-2013-mustang-gt-35k-miles-ac-not-working.html
No 8.
No 9.
Old Apr 22, 2016 | 07:31 PM
88lx50's Avatar
The likely failure was the clutch on the compressor. That can be repaired for cheap. Take a good look at the front of it and see if the rubber damper tore itself apart.
Old Apr 23, 2016 | 07:12 AM
Excelcius's Avatar
Thanks, I'll look into that. The problem is the metal pieces that ended up strewn throughout the system as opposed to the cost of the compressor.
Old Apr 23, 2016 | 11:41 AM
88lx50's Avatar
If it is just the clutch then there won't be any metal through the system. The system does not have to be opened either. The dealer will sell you a new car if you let them.
Old Sep 29, 2016 | 03:11 AM
3point7's Avatar
The AC system on these cars in the last few years is utter crap 88LX. Complete system failure between 30 and 50K miles is very common. Ford is ignoring it just as fast as they can right along with the crappy water pumps on the 3.7 motor and the bevy of rear axle issues.
Old Sep 29, 2016 | 05:02 AM
88lx50's Avatar
And the paint issues, and anything else they can blame on the customer. Sad, really. But don't trust a dealer when they want to sell you the world. Plenty of guys have gotten away with changing the pulley and clutch.
Old Sep 29, 2016 | 05:11 AM
3point7's Avatar
Yeah, the very first issue mine had was hood corrosion.
Old Apr 22, 2018 | 07:55 AM
Rod Kuffler's Avatar
Destroyed AC clutch on 2012 Boss 302
I'm not sure if the front AC clutch plate pics can be seen but this just happened while driving down the road for the second time this spring in my 2012 Boss 302 with 26K miles (40K km) on it. I assume the AC unit is seized and needs to be replaced.
I would like to know if I can drive the car to the dealer or should it be towed?
There is a sound like failing bearings when the car is running.
Old Jul 11, 2019 | 05:40 PM
Tracy Joiner's Avatar
Air conditioner went out a 3rd time!
[QUOTE=Excelcius;6978280]I have seen a few other threads detailing this issue but they are usually from a couple of years ago, but I was wondering, how many of you know about someone or have had your AC compressor fail and ruin your AC System? I drive a 2012 Boss 302 at 40k miles; my AC compressor destroyed itself as I drove down the road. The dealer quoted me $2,315 to repair and flush my system. My warranty has run out and no, I did not buy the extended warranty. I realize that this was a gamble, but I did not expect a repair equal to 8% of my car's value before 50k miles. I've seen other posts about this issue, and am surprised that this happens.
No 1.
No 2.
No 3. Attachment 178626
No 4. Attachment 178627
No 5.
No 6.
No 7. Attachment 178628
No 8.
No 9. Loyal Ford owner from birth. This is #7 but the worst of all. Bought 2nd hand at 52,000 didnt do my research found out it had PCM error a 1650 fix that was declined to be fixed by previous owner n Ford did not fix it. I bought it and extended warranty. Had to fix sway bar, driver seat, actuator switch n ac none covered by extended warranty 10/2015. August 2016 during flood AC went out. Had mechanic replace condenser, compressor, dryer and blower. A year later 2017 AC went out again!! Replaced all parts again 1500.00. Replaced struts, spark plugs, do regular oil changes with Mobil 1, battery, did transmission flush, air filters regular, sway bar 2nd time, cleaned cabin filter caused 2 inches of water to spill out onto custom mats and July 2019 AC went out again. Clutch for AC messed up and it is suggested I replace all parts again another 1500.00. Just at 110,000 miles. I have bought bout 12 vehicles for myself n helped by 4 for others co-signing and I have never had any other vehicle have this many AC issues EVER under 72,000 miles much less 3 times and the paint bubbling which seems to be a Ford mustang issue for last 10 years. I am so dissappointed!! I have spent so much money remaining loyal to by American and owned 7 mustang's different years. I am finally deciding I'm done like wayyyyy done. Gonna get rid of this one and I will not be buying another one. What do the rest of you loyal Mustang folks buy that doesnt need so much "fix and repair daily" as the rest of the world has always made fun of my loyalty saying. I need suggestions want a vehicle that last I mean doesnt need major repairs to at least 72,000 miles. Cars used to be built better. I am in shock today and just cant believe my AC went out a 3rd time n I live in Louisiana!! U cant go without AC here period!!
Old Apr 16, 2020 | 10:41 AM
DanielChandler's Avatar
I suggest you to call an expert who specializes in doing SPAM REMOVED, from these experts you will come to know about the control module and compressor replacement.
Old Apr 16, 2020 | 04:58 PM
EF1's Avatar
EF1
The compressor on my 2011 GT let go last summer with a little over 80k miles while at Road Atlanta for a NASA event, and no I wasn't on the track at the time. I was putting through the paddock at 10 miles an hour on my way to the concession stand when it started grinding. I wasn't sure what it was so I shut everything off and when I turned it back on no noise, but it was blowing warm air. I cut the belt off the compressor (the ac compressor has a separate belt) and finished the weekend out. It can't do any more damage if it is turned off and isn't spinning. I didn't get around to fixing it last fall and put the car up for the winter. I am getting ready to dig into it, but I think it is just the clutch. I have had a few friends that track their cars and have had ac failures with relatively low miles. One had two failures in less than 50k miles before he learned to turn it off while on track. One under warranty and one on his dime. The compressors don't like high rpms for extended periods.
Krohn
2012-2013 BOSS 302
33
May 13, 2014 12:48 PM
Honus
Aug 25, 2012 07:26 PM
Enator
Jul 3, 2012 05:01 PM
APW
2012-2013 BOSS 302
30
Jan 16, 2012 08:20 PM
PTRocks
2012-2013 BOSS 302
26
Jan 30, 2011 06:40 PM
