2012 5.0,lots of smoke cylinder 8 misfire.
Old Aug 1, 2011 | 07:39 PM
  #101
BlackOut2k11's Avatar
Originally Posted by unas2k5
No, never sprayed it and no spirited driving that day...
Thanks guys for your input.
BRENSPEED says its a motor issue and NOT THE TUNE.
One of my friends who use to work for Ford says that he can hook it up to his computer and read the tune for me. What info do you guys want to know that may give us a better understanding of the issue?
Would thisMMR Street Mod 1000 Rotating Assembly for 2011/2012 5.0 solve the cyliinder 8 issue for good?
If the guy can really look at the factory ford tune, have him check if the stock calibration is doing anything funky with cylinder #8 anywhere in the RPM range, specifically up top. Might shed some light on if there IS a flaw and ford is trying to mask it through their tuning procedures.
Old Aug 1, 2011 | 08:02 PM
  #102
unas2k5's Avatar
Originally Posted by VegasGold
Did BRENSPEEN check out your motor? If so, what was the cause if they know it is a motor issue...Thank you...
No they didn't check the motor.
Old Aug 1, 2011 | 08:03 PM
  #103
unas2k5's Avatar
He's going to try and read the Brenspeed tune and I'll ask him to try and read the Ford. I'll keep you guys posted thanks.
Old Aug 1, 2011 | 08:05 PM
  #104
unas2k5's Avatar
HAS ANYONE LINKED OR SEEN A LINK TO THIS THREAD AT ANOTHER FORUM? I HEARD THERE WAS AND THERE WAS INPUT FROM BRENSPEED ON MY SPECIFIC ISSUE.
Can you please link me?
Old Aug 1, 2011 | 08:29 PM
  #105
jaybertx's Avatar
Originally Posted by Turboba6
Ford KNOWS that 95% of folks buy Mustangs
To Mod them
And they know that 92.67% of statistics are made up on the spot.
Old Aug 1, 2011 | 08:33 PM
  #106
DetTigers's Avatar
http://www.s197forum.com/forum/showthread.php?t=66474
Old Aug 1, 2011 | 08:53 PM
  #107
VegasGold's Avatar
Can you post it. I can not get in, thanks...
Old Aug 1, 2011 | 09:12 PM
  #108
DetTigers's Avatar
Copied from S197 forum, this is what Brenspeed posted-
This is actually the 3rd customer who has contacted us about this issue. 3rd customer in the last year and of those 3 we have probably sent out atleast 500-600 2011 5.0 tunes. The first customer of ours who blew a number 8 the Ford engineer covered it under warranty due to an oil squirter failing, the second (who i believe is a member on here) broke a rod bearing (split in half) and the third customer is this customer who you are reading about and the car hasnt been to the dealer to diagnose the issue. We have also heard of long tube headers causing this issue as well, which i find it very hard to believe, but again there are no facts, just speculation. The funny thing is that everyone is blaming the tune, but this is an ongoing issue (according to our local ford dealer) on the FORD tech forums and there is a lot of finger pointing going on. You all are just hearing about cars with tunes having these #8 issues on forums, but if you look at the facts 90% of the 5.0 customers on forums have their cars modified and are running tunes. These issues are happening on FRPP tunes as well as 100% stock cars, so its very hard to place the blame on the tune. All of the cars that we have heard about having this issue have been EARLY production cars, but who's to say that has anything to do with it, because we dont know the facts and probably never will. We have been running our most aggressive Race tune (more aggressive than we send out to customers) on our 2011 test car for the last 16k miles (on 93 pump gas) and have raced it at nearly all NMRA events and definitely a LOT of spirited driving and abuse (naturally aspirated and with over 600rwhp to the wheels with a Vortech). We also have 2 other 2011-2012 in house test cars with ZERO issues as well. Ford's OEM calibration has parameters in place to protect the engine and we DO NOT remove these calibrations or alter the parameters. If anyone has any concerns or questions feel free to call me anytime. I can be reached directly at 574.594.9559 ext 3.
Thanks,
Chandler
Old Aug 1, 2011 | 09:21 PM
  #109
unas2k5's Avatar
Thanks,
Chandler
When was this posted?
Old Aug 2, 2011 | 12:10 AM
  #110
unas2k5's Avatar
http://www.svtperformance.com/forums...kryponite.html
Old Aug 2, 2011 | 06:16 AM
  #111
DetTigers's Avatar
I believe 2 days ago. You are the 3rd customer he's referring to.
Old Aug 2, 2011 | 07:34 AM
  #112
unas2k5's Avatar
Thanks, I just ran into it at the s197 forum.
Old Aug 2, 2011 | 07:52 PM
  #113
unas2k5's Avatar
This is a rotating assembly that I'm considering:
http://www.modularmustangracing.com/2011_parts.htm
Up to 1000HP!
This is everything you need except a block to assemble a complete fully forged shortblock, this kit has the same parts as the MMR Street Mod 1000 shortblock but in a do it yourself kit. Available in all piston oversizes.
Includes:
Brand New Ford Racing Forged Crankshaft- fully counter weighted, will handle up to 1500HP
MANLEY 4340 Forged H-beam Rods with ARP Bolts
MANLEY Forged Pistons with steel Pins
Total Seal Rings
Clevite Performance Rod Bearings
Factory Ford Main bearings 1 year Warranty
Old Aug 2, 2011 | 08:07 PM
  #114
ShaneGT's Avatar
Up to 1000HP!
Includes:
Total Seal Rings
would be the way to go, IF the cylinder is fine..
Old Aug 2, 2011 | 08:19 PM
  #115
If the cylinder is boogered up he can just replace that liner (honed to the same specs).
Old Aug 2, 2011 | 09:17 PM
  #116
unas2k5's Avatar
Should I go with a 10.0:1 9.0:1?
How strong are the stock heads?
Thanks guys...sorry for all the questions.
:beers:
Old Aug 3, 2011 | 05:55 AM
  #117
ShaneGT's Avatar
:beers:
how much boost you plan on running? more than 16, go with 9.0:1 to be safe..
Old Aug 3, 2011 | 06:07 AM
  #118
:beers:
If you wanna stay N/A go with 11:1 (stock compression). Low boost go 10:1, high boost go 9:1.
Old Aug 3, 2011 | 09:07 AM
  #119
Imatk's Avatar
I've read about several people having issues with MMR. I have no dealings with them at all so I have no idea.
But make sure you do your research before you buy.
I went through the same thing so I feel ya... I know you want to get your car done and back as soon as possible, but TRUST ME make sure you get EXACTLY what you want for your future plans.
I agree with the above statements... if you're going boost then I would drop it down if not stay with the stock compression.
The aluminator is running 9.5:1 and I would say that's probably perfect.
Too low of compression and your car will be a dog "off boost" and might be a PITA to drive.
In other words... if you have a lower compression you will have lower NA power and when the boost kicks in you could run into a sort of "instant-on" feeling where you literally are going slow then BAM the car is running away from you.
9.5:1 will give you good NA power and should deliver a smooth transition to boosted power.
Assuming this is a street car, which I assume it is... if not then that's a whole other ball of wax.
Old Aug 3, 2011 | 09:27 AM
  #120
MRGTX's Avatar
I'm just going to throw this tidbit out there again-
The thing that chaps my buttocks about this is that it appears that Ford will write off your ENTIRE warranty with any the evidence of a tune at any point in the car's history.
So if you bring your motor in for a problem that has nothing to do with the tune...or if it burns up #8 long after a tune has been removed, you're done.
Most responsible people wouldn't try to make someone else pay for something that was clearly their own fault...but when the other party walks away from it's responsibility and puts the impossible burden of proof on the consumer, there is a problemo.
Originally Posted by cdynaco
As a reminder, its best NOT to check them after you've been idling very long.
Back in the day when the only way to check your (main jet) mixture was by checking the color of your plugs, they always said it was best after driving under a slight load - like up a mild grade. Then pull em and check the color/snap a pic for a truer reading.
Good tip.
Also as another "common sense" reminder, don't attempt this without a torque wrench. Overtighten that plug and you'll live to regret it.
Carry on, fellas!
