Raxiom Navigation w/ Bluetooth & Back-up Camera (10-14)
Old Mar 17, 2014 | 03:26 PM
  #121
Gtstyles2's Avatar
Originally Posted by wheelman
Not sure about prior years, but on a non-nav '13-14: Aux>Menu>Select Source>Bluetooth Audio IIRC.
Hmm I'll try that on my Focus, it's also SYNC and I drive that a lot more. I hate being forced to use voice
Old Mar 22, 2014 | 10:34 PM
  #122
rockpolisher's Avatar
I'm trying to find out what I need to do if I have the 6 disc player with sync.
Old Mar 24, 2014 | 09:23 AM
  #123
conv_stang's Avatar
They offered a 6 disc changer for 2010-2014?
Old Mar 24, 2014 | 10:40 AM
  #124
MDkid92's Avatar
haha yeah, since when was this an option?
Old Mar 24, 2014 | 03:30 PM
  #125
Canadian models all 2010 GT's come with it. Dumb cuz I don"t even use CD's. I've seen a few other ppl ask the same question but was never confirmed if all I need to do is swap to a single disc from a 2011 and up model. Would I also need to swap the display? Would I need a re-program from the dealership for it to work?
Old Apr 2, 2014 | 10:38 AM
  #126
JoLC_F's Avatar
Looks awesome!! Gonna do little more research on it and it'll probably be my next upgrade!
Old Apr 20, 2014 | 05:22 PM
  #127
I'm having problems with gps trying to pick up signals from the satellites. Everything else works good except for the navigation. GPS antenna is mounted on the rear decklid. Do you think it's the gps antenna at fault or sd card?
Old Apr 20, 2014 | 06:27 PM
  #128
Thomas S's Avatar
I was having that same problem until I moved the antenna towards the middle of the decklid. Now it's just fine. I think it needs a straight shot to the sky and mine had slid behind the C pillar.
Old Apr 20, 2014 | 08:43 PM
  #129
Tried that. I moved the antenna to the front dash and still have no signal. It's say 0 satellites. This sucks.
Old Apr 20, 2014 | 09:57 PM
  #130
ranbon12's Avatar
I think it must be antenna or wiring. For example, I have a convertible and mounted mine in the console storage compartment. True I don't get every sat, but I have no complaints. If mine can be useable from there, I can't see how it wouldn't work on the deck lid.
Old Apr 21, 2014 | 01:41 AM
  #131
Thomas S's Avatar
You might wantto check the connection on the back of the unit.
Old Apr 21, 2014 | 01:55 AM
  #132
I took it apart 3 times and checked all my connections. I'm betting it's a bad gps antenna. Gonna call AM and go from there.
Old Apr 21, 2014 | 05:32 PM
  #133
All fixed and everything working. All it needed was a sd card update.
Old Apr 21, 2014 | 06:15 PM
  #134
There are 2 camera plugs. Brown one says camera one connected to the reverse camera. There's also a blue one that says camera two. I'm guessing you can add another camera to that plug but where can I buy the camera with the wire that plugs into that blue plug?
Old Apr 22, 2014 | 10:49 AM
  #135
trizzot's Avatar
On mine, The steering wheel volume button does not work. All other steering wheel buttons work fine. I've been working with AM for about three weeks with no luck. I hope they figure this out soon. Many things have been tried, switching cables, factory reset button. Other than not having all functions on my steering wheel, I like the unit.
Old Apr 22, 2014 | 12:46 PM
  #136
zeroaviation's Avatar
What's your vehicle details?
-Matt
Old Apr 24, 2014 | 02:30 PM
  #137
trizzot's Avatar
2013 GT Premium. AM is sending me a new unit. Ill swap them and report back when it come is.
Old Apr 26, 2014 | 03:34 PM
  #138
In the menu screen, top right hand corner says keypad. When I press it, it goes to a password screen. What is the password for? I've been reading alot lately of questions being asked about this product that AM sells exclusively, it's awesome they haven't answered any of these questions.
Old May 6, 2014 | 12:03 PM
  #139
MOTO2000's Avatar
Does this unit show the bluetooth media stream text? Like if I am streaming music from my phone, does the song/track information show up on the screen?
Old May 6, 2014 | 12:20 PM
  #140
flynavy's Avatar
No it does not. If you plug your device in via USB it will. But not through Bluetooth audio.
