Possible solution to door rattle (Shaker 500)
Old Apr 2, 2013 | 10:32 AM
Rando's Avatar
I have the Shaker 500 system with Pioneer TSD6802R 6 X 8 2-Way 260 Watt Speakers. My passenger door rattles like crazy when I play music. I've had Ford look at it 3-4 times and they say everything is nice and tight. I've even made sure things are fine myself when I replaced the speakers. I've noticed that if I pull or push on the map pocket, the vibrations/rattles go away almost completely.
My question is, does anyone know of a small reverse clamp that I could put in there to test this? I've even thought of shoving a small block of wood in there. I'm not buying dynamat since it's so expensive.
Old Apr 3, 2013 | 04:52 AM
Mykap's Avatar
Had the same issue with my car.
Solved it by simply gluing a small diameter but thick piece of pipe at each end of the pocket to keep it rigid.
No effect on use of pocket and no more rattle.
I wrote a thread somewhere will find link.
https://themustangsource.com/f804/an...503567/index2/
Old Apr 3, 2013 | 05:21 AM
Reminisce's Avatar
yeah I found that that map pocket or anything in it will vibrate. I was thinking of doing something similar to what Mykap suggested.
Old Apr 3, 2013 | 06:49 AM
Rando's Avatar
Do you have any pics?
Old Apr 3, 2013 | 09:18 PM
Mykap's Avatar
will post next week - I am away from home at the moment
Old Apr 10, 2013 | 06:35 AM
Rando's Avatar
Waitinggg
Old May 1, 2013 | 12:04 PM
Mykap's Avatar
Sorry for delay- just done a mini world tour for work... Kazakhstan, Spain, Azerbijan now back in UK.
Solved mine by gluing in Plastic pipe as shown...
I also covered the rear of the panel with dynamat ie inside the door panel.
duppycat
Feb 16, 2019 08:36 AM
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
