Need Help with Wiring Interior LEDS
Old Mar 9, 2015 | 11:59 AM
mattsup94's Avatar
Question Need Help with Wiring Interior LEDS
So my buddy's bday is coming up and I wanted to suprise him with this lighting kit but I don't know how to wire it into his car. :
Amazon.com: 4pc. Multi-Color 7 Color LED Interior Underdash Lighting Kit: Automotive Amazon.com: 4pc. Multi-Color 7 Color LED Interior Underdash Lighting Kit: Automotive
I looked on the forums but didn't find a DIY tutorial. If anyone could offer me some help that would be greatly appreciated.
Old Mar 9, 2015 | 07:26 PM
clucas's Avatar
Looks like it just needs to be hooked up with a switch to turn it on. You could get fancy and hook it to a switch or to the parking lights to trigger a relay to turn them on. The simple way would be to run the power directly from the battery or fuse box with a switc to turn them on.
Old Mar 10, 2015 | 12:16 PM
mattsup94's Avatar
So I will be using that method (Wiring from the Control Box from the LED Kit directly to the fuse fox.. Does anybody know what size fuse I would need to get (2014 V6 Mustang. I believe it's mini?). I wanted to also remove the fuse from a switch power rather than a constant supply. Does anybody know which fuse is switched?
Old Mar 11, 2015 | 10:12 AM
DeeJayTJ's Avatar
search ambient lighting in the forums.. lots of info.
Old Mar 11, 2015 | 04:42 PM
Springer200's Avatar
Alternatively, wire it to a "cigarette lighter" (old name) adaptor (power port adaptor?) and plug it in when needed.
The power ports may be switched, I am not sure.
If you are going to wire it to anything, use a dome light wire, and if you are adding a fuse, it does not have to be a "mini-fuse" - a separate fuse of 1 or 2 amps should suffice. The instructions should say what the power draw is - I doubt it is much.
Old Mar 12, 2015 | 07:56 AM
DeeJayTJ's Avatar
i added ambient lighting to my car, my controller isnt necessarily made for a car but its 12v so it doesnt really even matter.
you dont have to add it to cigarette lighter and plug in when you want it, thats a terrible idea . Thats what things like relays are for a relay is basically an automatic switch.
https://themustangsource.com/forums/...7/#post6757005
Old Mar 12, 2015 | 10:26 AM
mattsup94's Avatar
I wanted to wire it to the fusebox rather than the cigarette lighter so the setup would be much cleaner.
The reason why I ask for the size is because there are specific fuse sizes for cars and I wanted to know what the size is for the mustang. I don't have access to his car to do this now so if anyone would know that would be awesome.
The link to the different fuse sizes for the expandable circuit:
http://www.ledunderbody.com/Expandab...-Amp-Fuse.aspx
Also does anybody have the fuse diagram for the 2014 V6 Mustang?
Old Mar 12, 2015 | 12:25 PM
I know what a relay is, but I am not sure the original poster does, nor is a relay needed. My thinking on my "cig adaptor" recommendation is - that this is not his car, and he has very limited experience with wiring. What if the guy hates it, or, like me, would not want someone else wiring on his car, evan as a gift?
I guess the fuse tap achieves the same purpose as a cig plug, but I got the feeling that he was not that familiar with using a fuse tap, and a relay is way over his skill level (and probably not needed for this, as I am thinking that the dome light circuit could easily handle the added current draw unless that LED controller draws some stupid amount of power).
My thinking was that if he had a "test light" and a basic understanding of wiring, he wouldn't be asking these questions. I am not trying to bash him, or discourage basic questions - that is how you learn. My apologies if my assumptions on skill level are incorrect, as its difficult to judge skill level in a posting.
Old Mar 17, 2015 | 12:23 PM
mattsup94's Avatar
Soo can anyone answer my question lol? What fuse size do I need to get for the expandable circuit and which fuse has a switched power supply that I should use?
May 3, 2026 05:42 AM
RCooke08GT
Feb 19, 2017 03:03 AM
mmb0329
Oct 1, 2015 10:59 AM
