How to get to trunk light wiring in 2013 GT?
Old Oct 19, 2012 | 10:33 AM
jocatch's Avatar
I would like to add a couple of LED light bars inside the trunk of my 2013 GT to get more light. The problem is I don't want to tear up the whole trunk to get to the wiring nor do i want unsightly wires showing. Since I want the LEDs to go on and off with the trunk light, I need to tap in the wiring at the bulb. Not sure how the paneling comes apart. Any ideas?
JC
Old Oct 21, 2012 | 10:58 AM
White5ohh's Avatar
JC
I went behind the panel the latch is built into and spliced into the trunk light wires. Easiest and cleanest way
Old Oct 21, 2012 | 09:25 PM
watchdevil's Avatar
JC
There are four fasteners. There is a large screw **** behind each tail lamp and two small push pin fasteners low in the trim panel. Very easy to remove the panel and access the wiring to the trunk lamp. I put a 36" white self adhesive led light strip under the rear deck tray. It really fills the trunk with light and looks hi tech.
Old Oct 22, 2012 | 12:26 PM
Xtian85's Avatar
I took the power off of the bulb in the trunk. Pulled it out far enough and then used T tap connectors.
Old Oct 23, 2012 | 07:25 AM
White5ohh's Avatar
Ditto
Old Oct 26, 2012 | 02:34 PM
jocatch's Avatar
Thanks for the input on how to remove the rear panel. I ordered this light bar which just came in today. Plan to install this weekend...
Joe C
http://www.superbrightleds.com/morei...hip-leds/1084/
Old Dec 20, 2012 | 08:54 AM
sms888's Avatar
So I started to do the same thing in my GT. T'd into the existing harness but I think I popped a fuse and now have no power to the factory light. Anybody know which fuse or any ideas as to what I did?
Old Dec 20, 2012 | 07:52 PM
MontrealStang's Avatar
Fuse position # 25; It is a 10A fuse/amp rating.
Old Jan 4, 2013 | 07:34 AM
sms888's Avatar
Right, it was #25. Lights work great now, thanks!!
Mpaps
Oct 11, 2017 08:06 PM
JonsMustang
Mar 5, 2016 05:44 PM
14Glassback
Sep 11, 2015 04:50 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
