Big 2/3 Upgrade?
Old Mar 8, 2015 | 04:24 PM
05PRMTX's Avatar
Big 2/3 Upgrade?
Has any one done this? I started looking at it yesterday and there isn't really a good path from the alternator to the battery. I'm worried the wire is going to be too close to the engine. As you can see in the pic it would be running basically right next to the header....
Old Mar 8, 2015 | 07:25 PM
What is a 2/3 upgrade?
Old Mar 8, 2015 | 07:44 PM
clucas's Avatar
im guessing it's a reference to upgrading the alternator to battery, then battery ground cabling.
I haven't upgraded my cabling, but I've never seen my voltage drop below 13.2 volts while running. I'm not running a ton of power, but I do have two amps and a processor running off a 1/0 run to the trunk. I'd have to look in the engine bay to really see a good run, but I would probably pull it straight up the inner fender and then run the cabling behind the engine, or maybe try to run it up the engine and maybe under the engine cover back to the firewall. Also, I'd definitely be using flex tech/expandable sleeving on the cable to help protect it while under the hood.
Old Mar 9, 2015 | 07:28 AM
05PRMTX's Avatar
Yea sorry guys I guess I should have specified.It's the The electrical system wire upgrades. From what I have gathered, newer cars don't require the engine block to chassis wire upgrade, so its essentially the big 2 now. Alt. to battery+, battery- to chassis.
Old Mar 9, 2015 | 07:39 AM
05PRMTX's Avatar
Mine is definitely dropping, or else I probably wouldn't bother with it. I'm running 1/0 to the trunk, and I have a rather large 4ch amp. The mono amp is no small foot print either. Anything with good low-end punch causes my headlights to dim. I think I'm going to try to go straight off the alt to the fender wall like you were saying and see if I can find something to secure it to, to keep it away from the header. Yes I will definitely be covering it with sleeving, as I did with the part of my power wire thats in the engine bay. I ordered a bunch of blue sleeving from summit racing. Should look nice if its the shade shown on their website,
Old Mar 9, 2015 | 07:21 PM
clucas's Avatar
The blue sleeving sounds like a good touch. I'll be curious to see how much of a difference it makes. I know it should make a difference, but if you're seeing voltage drops then I'd like to see how much the voltage drops are alleviated.
I think I'm not seeing quite the drops because I have a class d 4 channel bridges to my midranges and my big 4 channel is barely being pushed due to my subs being in an IB configuration.
Old Mar 9, 2015 | 10:14 PM
Jazzman442's Avatar
How much is yours dropping? What size where you running before? What test points where you measuring from?
Old Mar 10, 2015 | 08:34 AM
05PRMTX's Avatar
That's a good possibility.Eventually I would like to get newer, more efficient amps. I've had these beasts for about 8 years now and still love them though
4ch: http://archive.mtx.com/caraudio/prod...hunder7804.cfm
Mono: http://www.crutchfield.com/S-bsnHjwm...under5601.html (run a 2 ohms)
I'll do a before and after test
Old Mar 13, 2015 | 11:27 AM
05PRMTX's Avatar
Did a test and its dropping by a volt when the lights start dimming. Need to order some new battery terminals to account for the new wires, so that has put a slight delay on things.
kponypower
Jun 17, 2020 07:17 AM
wallace
Mar 29, 2016 10:09 AM
trackpack13gt
Oct 2, 2015 08:20 PM
GeoWett
Sep 30, 2015 06:40 AM
wannabe
Sep 23, 2015 05:36 AM
