Notices
Aftermarket Keyless Start Button
Old 11/12/15, 09:24 AM
  #61
jim010's Avatar
Sorry, I haven't had time yet to post anything.
Old 2/25/17, 09:49 PM
  #62
Kona12GT's Avatar
It's a bummer you never got the time to post how you did this. I guess I will try to figure it out myself.....lol.
Old 3/1/17, 05:59 PM
  #63
Slowb00st's Avatar
Kona12GT I guess you have kit, I have one that's been sitting for a few months only thing keeping me from installing is the stock alarm.
Maybe we can trade install notes, if we ever actually do the install.
Old 3/1/17, 10:25 PM
  #64
jim010's Avatar
I did install it, so yes I can help with the wiring.
Old 3/2/17, 02:00 PM
  #65
Kona12GT's Avatar
I have not bought it yet..lol. Just trying to plan.
Old 3/2/17, 02:31 PM
  #66
Slowb00st's Avatar
Is the ALCA only for the PATS system bypass? Did your car have active alarm system?
I see.
Old 3/2/17, 03:54 PM
  #67
jim010's Avatar
Yes, the ALCA is for the PATS only
Old 3/9/17, 06:04 AM
  #68
GT227's Avatar
How does the system work, Jim? Any issues with it that you found? Assuming you like it?
Old 3/10/17, 08:39 AM
  #69
jim010's Avatar
The system does work, but I needed to iron out quite a few things with the tech support. You do lose the stock alarm and it is replaced with the easygo system.
Old 12/29/17, 02:17 PM
  #70
Kona12GT's Avatar
Anyone wanting to do this, the kits are getting cheaper on amazon. I am about to attempt the install as soon as I get it next week.
Old 1/3/18, 07:10 AM
  #71
GT227's Avatar
**** these are cheap on amazon now. Grabber blue is only $150. I'm tempted to get this.
Old 1/16/18, 07:36 AM
  #72
Kona12GT's Avatar
Jim, sent you a PM to see if you had any docs on the wiring or any tips on installing. I have a 2012 also. Thanks in advance.
Old 1/16/18, 01:02 PM
  #73
jim010's Avatar
I do have info for wiring it all up. I will type it up and have it posted tomorrow sometime so everyone can see how it is to be wired. The instructions in the kit are useless. I needed the tech help and a whole lot of wiring diagrams to help me with this.
BTW, I am selling my kit for Red Candy if someone wants it.
Old 1/16/18, 01:27 PM
  #74
Kona12GT's Avatar
Here is the button I got.
Old 1/16/18, 01:31 PM
  #75
jim010's Avatar
That's a nice button. Mine was red with gloss black ring. I think I prefer the button in red, though.
It will fit. It is off center so you don't have to modify the power port bezel at all. I customized mine and had it centered as I don't like the off center look.
Old 1/16/18, 01:38 PM
  #76
Kona12GT's Avatar
Yeah, if I had red on my car I would like it more also. My car is Kona blue.
I am having a hard time getting the button into the door...lol. The housing on the back of the button is quite large compared to the hole opening...lol. I may mount it in the dash like that other guy did. Have to get my door handle painted first and warmer weather to start on this...lol.
Old 1/16/18, 01:43 PM
  #77
jim010's Avatar
The ring may not be oriented properly it it doesn't snap in place. It should fit nicely.
Old 1/18/18, 08:38 AM
  #78
jim010's Avatar
OK, here you go. I did not take pictures, but this is the way it has to be wired up. I made all the notes, but I no longer remember what some of this means, so you are on your own here. I can tell you where the connectors on the car are, but that is it. This was a couple years ago, so if you ask me details, I may not remember.
On the EasyGo 16 pin harness
EasyGo -------------------- On The Car
1 +parking Light ---------- connector 2280E pin 6 green tape
2 +parking light ---------- connector 2280E pin 6 green tape
3 -horn -------------------- connector 2280B pin 41 red tape
4 -door lock --------------- connector 2280C pin 17 green white
5 -door unlock ------------ connector 2280C pin 4 gray/blue
6 -parking light ----------- connector 2280B pin 31 purple/green
8 bypass ------------------ idatalink - ground when running black to blue/white
10 -trunk release -------- connector 2280C pin 20 black & black tape
11 can low (yellow) ------ connector 2280B pin 38 (also connector 251 pin 11 yellow/brown)
12 can high (purple) ----- connector 2280B pin 37 (also connector 251 pin 3 white/blue)
13 +brake wire ----------- connector 2280B pin 40 (also connector 278 pin 4 red)
14 -door trigger ---------- driver door connector 2280C pin 14 green
16 bypass ---------------- idatalink - constant 12V red to red
idatalink
Connector 2007 to PATS - (orange/black - 3) (gray/red - 4)
connector 250 to ignition - pink - 1
*and remove pin 5 blue/gray
87 - idatalink blue/white ground while running
EasyGo 12V+ (brown wire on 6 pin connector) - 86
85 & 30 - ground
Kona12GT (3/30/18)
Old 1/26/18, 09:04 AM
  #79
jim010's Avatar
How did the install go?
Old 1/28/18, 12:29 AM
  #80
Kona12GT's Avatar
Have not had the time or good enough weather to do it yet. Also still waiting on my handle to be painted.
Quick Reply: Aftermarket Keyless Start Button
