Adding rear AMP to Shaker 500 on 14 GT
Old Jun 15, 2014 | 07:46 PM
  #41
DJ2014's Avatar
Originally Posted by clucas
I did not drill any holes in the plug. When you pull the molex out of the boot you can separate the molex from the piece that locks the boot to the body of the car. Once you do that you can push the molex down into the car and run the wires through the boot, effectively going around the molex.
Doesn't sound too difficult to do then. I just may have to tackle this.
This may seem like a dumb question, but when the front speakers are amped, do they over-power the stock woofers in the doors? In other words, can you still hear the bass coming from the oem woofers? Thanks.
Old Jun 16, 2014 | 11:47 AM
  #42
14stangGT's Avatar
Sorry I have not logged on awhile. I did not have to drill anything. The PAC has line level adjusters on it as well as your amp ( it should) I would adjust those before you adjust it on your radio fader. That way you keep the full sound to your fronts. I added a Clarion eq for (55) in the trunk to adjust the sound to my rear deck speakers as well I will post some pictures tonight. Pretty good sound for the $$. I do not get any engine or alternator noise in my set up.
Old Jun 16, 2014 | 11:54 AM
  #43
14stangGT's Avatar
https://themustangsource.com/f803/ho...s-pics-494868/
Here is another good link with pics
Old Jun 16, 2014 | 12:05 PM
  #44
DJ2014's Avatar
I saw what looked like adjustment screws on the PAC but wasn't sure. So that's where I could adjust each speaker instead of fading it? I have the Clarion XC1410 amp and it doesn't have any adjustment on it, just the high level/low level inputs. The electrical hum is so low you can barely hear it. I'll have to check into the Clarion eq also.
Old Jun 16, 2014 | 12:07 PM
  #45
DJ2014's Avatar
I found this link a while back and used it to do mine. Great write-up and pics.
Old Jun 16, 2014 | 12:35 PM
  #46
14stangGT's Avatar
http://www.amazon.com/Clarion-EQS746...rds=clarion+eq
here is the eq I got
be careful I noticed the site changes this link to walmart it is $55 at amazon and $105 at Walmart
Old Jun 16, 2014 | 12:39 PM
  #47
14stangGT's Avatar
Here is my old amp and the clarion EQ mounted to the box I built
Old Jun 16, 2014 | 12:48 PM
  #48
14stangGT's Avatar
I have 3/4" inch aluminum spacers between the box and the amp & crossover
Old Jun 16, 2014 | 12:51 PM
  #49
14stangGT's Avatar
and here is what it looks like in the front. I used tie downs just in case the box does fit pretty snug though. I have to puts a little with the eg but it does improve the sound and no noise either. I wish I could get it in the front but I do not want to cut anything and I want to keep the factory HU.
Old Jun 16, 2014 | 12:55 PM
  #50
14stangGT's Avatar
Yep you gain adjust the output gain there.
Old Jun 16, 2014 | 02:52 PM
  #51
DJ2014's Avatar
All right, thanks!
Old Jun 17, 2014 | 08:29 AM
  #52
14stangGT's Avatar
I honestly can't say, but they're both really cheap brands. I would stick to at least a Polk, Alpine, JBL etc.
I tried the Alpine spr69 did not like them they distorted quickly, I am just sticking with the Infinity reference 9632cf they were 79 on amazon. It sounds a whole lot better then before. Thanks on the baffles I was not thinking correctly on that one.
Old Jun 17, 2014 | 08:32 AM
  #53
Which Alpines? Good to hear you got the Infinity's sounding better though...
Old Jun 17, 2014 | 07:59 PM
  #54
clucas's Avatar
I'm not using the factory subs in my car. I have some peerless 8" in the doors right now. They have some issues, plus I need to work on the EQ. The new wires in my doors were for what was originally to be a three way in the door, but I've changed to a two way front set up. I have hlcd horns mounted under the dash and the 8" in place of the factory subs.
Old Jun 17, 2014 | 08:06 PM
  #55
Show me the horns!
Old Jul 17, 2014 | 03:40 PM
  #56
DJ2014's Avatar
I just installed this same eq and what a difference it makes. Now to amp the front speakers and add the eq to them also (if it ever quits raining here).
Old Jul 18, 2014 | 01:43 PM
  #57
05PRMTX's Avatar
Show me the horns!
+1!!
Old Jul 18, 2014 | 01:45 PM
  #58
05PRMTX's Avatar
Good info on the PAC guys, thanks. I am kind of considering this now. Sounds like the line quality is decent. Why you guys are amping the rear speakers is still beyond me though lol.....but to each his own I guess.
Old Jul 18, 2014 | 02:46 PM
  #59
DJ2014's Avatar
I'm used to it growing up with older cars with rear speakers. I prefer to be surrounded by the sound, just not coming at me from the front only. I'm hoping to run the speaker wires to the doors next week.
Old Jul 18, 2014 | 06:00 PM
  #60
05PRMTX's Avatar
I hear you there. I was the same way with all my previous cars. Im just used to doing the fronts first. I will be interested to hear how it all sounds. I keep changing my mind on how to go about mine
