wheel&tires
Old Sep 9, 2011 | 10:30 AM
Gunner 2's Avatar
wheel&tires
Will nitto 555 285 40 18 fit on a stock 2010 gt rim?
Old Sep 9, 2011 | 12:32 PM
Ltngdrvr's Avatar
You could put it on but it is really too wide for the wheel to work the best.
Old Sep 9, 2011 | 05:17 PM
2012GT's Avatar
Will it work, yes.. will it be safe, no. You can pick up 18x10's at American muscle for a real good price.
Old Sep 10, 2011 | 12:20 PM
Dave07997S's Avatar
Wow these posts are over and over again..like its the twilight zone or something. I almost pointed you over to the search button..however.
A 285/40/18 Nitto 555 requires a 9.5" wide minimum rim width...so that should answer your question. Also the 9.5 would not be optimum...10" would. Think about it for a second... You have a tire that is 285mm wide or over 11" wide and you want to stick it on a rim that is only 8" wide.....so no it won't work.
Dave
Old Sep 10, 2011 | 12:22 PM
Dave07997S's Avatar
It won't even work...I can assure you most tire installers won't install this tire on this rim for liability reasons.
Dave
Old Sep 11, 2011 | 09:11 PM
You'd probably be able to just drop the wheel in the tire haha
Old Sep 12, 2011 | 01:16 PM
MRGTX's Avatar
This would make it a lot easier to check your tire pressure.
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
