Fogs turn off automaticallt when brights go on
Old Nov 24, 2011 | 07:28 AM
mtnbikefuel80's Avatar
I've noticed that when you turn the brights on the fog lights turn off automatically. Is there a way to have both on at the same time? The brights don't do a very good job of lighting up the road directly in front of you at all. I'm not sure how much extra current draw the lights take in the bright setting and if that's why it wont power them both at the same time, but if anyone has any ideas let me know! Thanks
Old Nov 24, 2011 | 08:02 AM
Overboost's Avatar
I believe it's a regulation not to have both on at the same time, not a power issue. You can modify the headlamp relay so that the fogs are sourced from a another portion of it, such as the running lamps, so they won't be interrupted when you switch from low to high beams. Without looking at the wiring schematic, I couldn't tell you exactly which wires to splice/bypass, but it's usually a simple thing.
You might want to check the 05-09 section for the same thing.
Old Nov 24, 2011 | 11:27 PM
houtex's Avatar
There is no regulation that says the low/fogs/driving lamps must be turned off if the highs are on, last I checked. And I checked, given the issues Mark VIIIs have with their lights on the Gen 1s.
Further, seems to me that other cars don't do this either. It's a Ford thing, I've always thought, on this. Much like why they also have 3 lamps in the tail lamps from '94 to 2009, but only use the outside two of them for brake lights... Why? Dunno, just the way it is. Maybe contrast.
Old Nov 24, 2011 | 11:30 PM
11SHELBYGT500's Avatar
My 96 lit all 3.
Old Nov 24, 2011 | 11:31 PM
07S197's Avatar
Swamp Donkey Man Cans
It's not just a Ford thing. Every car i have owned has been that way if they are factory installed. Toyota, GM, Ford, Nissan, Dodge.
Old Nov 25, 2011 | 05:46 AM
VTXFrank's Avatar
Typically, there is a single wire you have to cut. This wire senses when the Hi-Beams are turned on and cuts power to the fogs. I have not seen any one post which wire that is. My Trailblazer SS had the same thing with the fogs turning off. So did my Dodge truck and so does my wifes Nissan Frontier.
Old Nov 25, 2011 | 07:53 AM
voyager_1700's Avatar
Regulated per state.. NJ (sorry to say) does regulate this
Fog lights: These auxiliary driving lights may be used with low-beam headlights to
provide general lighting ahead of a motor vehicle, specifically during foggy weather
conditions (N.J.A.C. 13:20-32.25).
They use to test for it during safety inspections to make sure fog-lights shut off when high beams are turned on.
I had a Mini Cooper with "Running lights" & "Fog lights" Running lights work when high beams are on, Fog lights work when low beams are on.. I'm sure you can change or re-wire to your preference..
Just double check your state laws....
Old Nov 25, 2011 | 08:11 AM
spike's Avatar
Virginia regulates this as well. I failed inspection on another car that had fogs that were independent of the high beam switch.
http://leg1.state.va.us/cgi-bin/legp...19VAC30-70-160
Car manufacturers will ensure their cars comply with regulations from all 50 states.
Old Nov 25, 2011 | 12:21 PM
No inspections in FL but I guess ill still need to check regulations to make sure its okay...then find the wiring diagrams is fix it!
Old Nov 25, 2011 | 01:49 PM
Yup.
Old Nov 25, 2011 | 02:10 PM
AlsCobra's Avatar
A Man Just Needs Some....
It's like this because of what the fog lights are designed to do. High beams point higher and are brighter. High beams in the fog will blind you. The objective of the fogs is to project light lower to illuminate the road under the fog.
Old Nov 25, 2011 | 02:13 PM
That's what's so funny about some (many) calling Mustang driving lights 'fogs'.
Old Nov 25, 2011 | 02:14 PM
jacostang's Avatar
I retrofitted both of my Fox GT's because they were the same way!
Old Nov 25, 2011 | 02:38 PM
HizliBullet's Avatar
I have a 2003 protege5 and even that car does what 2011 mustang does with the high beams turning off fogs.... I got so used to it
Old Nov 25, 2011 | 02:40 PM
Overboost's Avatar
I've rewired a number of Proteges to work with the fogs on. The other thing that people always asked for was running lights + fogs. Ford allows that, Mazda does not.
Old Nov 25, 2011 | 04:10 PM
07S197's Avatar
Yeah my Nissan does not either and with the 55w silverstars i have in there i don't need headlights too. Usually going to work in the am at dawn i just want running lights and the fogs.
Old Nov 25, 2011 | 07:01 PM
houtex's Avatar
Oh, FOGS. And or Driving lights.
My bad. Thought we were talking about low/high. Ugh. I'm sorry. In my mind, I'm thinkin' those are part of the regular lights... I always have them on anyway... so... yeah.
/I... can't remember a 96 that did the 3 light thing... unless someone's rewired them?
//Obviously, I'm gettin' old and senile and... what was I doin' here?
///lawn.
Old Nov 26, 2011 | 12:26 AM
Yea driving on the country roads at night deer like to jump out so its nice having the high beams on to look out for them ahead so you can react in time. However the brights do a terrible job lighting the road in front of you so I can't see previously hit road kill and pot holes. Welcome to country roads haha. That's why I'm trying to get both fogs and brights on at the same time, so much fun driving at night lol
lakersfreak
Jun 13, 2022 12:29 AM
kponypower
Jun 17, 2020 07:17 AM
trackpack13gt
Jul 25, 2017 05:29 PM
ricky1728
Feb 11, 2016 07:25 PM
