Exterior And Suspension Mods On The Way!!
More mods are on the way!! Wondering what you guys think. I already have the sportlines installed. Looking for some advice on ride quality, looks, and install. Can't Wait!!
Staggered AMR Black Wheel & Sumitomo Tire Kit - 20x8.5/10
Ford Racing BOSS/CS Style Lower Front Fascia
Ford Racing BOSS 302 Front Splitter
Ford Racing GT500 Style Strut Mount Upgrade
J&M Rear Upper Control Arm
J&M Rear Lower Control Arms
Roush Rear Valance
Eibach Anti-Roll Sway Bar Kit
Mustang GT Eibach ProDamper Shocks and Struts
Roush Rear Valance
That's good to know now lol. I knew I should have trusted my instincts. I asked A represenative from AM about some concerns I had about them and they assured me they would be just fine. Do you know what may have caused it?
You can check out the following article we did on the LCA's ... gives some pretty good insight:
http://www.steeda.com/blog/2013/07/n...created-equal/
Best Regards,
TJ
Best Regards,
TJ
Best Regards,
TJ
Best Regards,
TJ
You might have some clunking with that UCA. Personally I would have gone with the BMR UCA and mount but that is me lol.
This was a post made by Kelly at BMR about UCA
It all seems pretty simple to me. This is because we engineer all of our components individually, to work with OEM parts.
That said; the 2005-2010 Mustang uses a 14mm UCA to Mount bolt. The 2005-2010 UCA is also 1" shorter, than the 2011+ UCA. Due to this, the mounting position on the 2011+ UCA Mount is also 1" further forward.
Here are some pictures to show the difference. These are BMR Components, UCA/Mount specific to 2005-2010 and BMR UCA/Mount specific to 2011+:
(The 2011+ Pieces are the pieces that appear "beefier") and have larger hardware/holes.
That said, here is a shot showing the 05-10 and 11+ OEM Pieces:
Here is why most aftermarket UCA will clunk when installed in an OEM Mount:
Here is why it does not clunk with an aftermarket mount:
And here is why the clunking is not so prevalent/common with OEM pieces, even though the tolerance is sloppy - they are designed to not clunk via:
As you can tell, the OEM engineering did not work well for us. We started getting a clunk at 450 miles on our car, due to the OEM Sleeve design not quite "holding on" for us.
The simple part is, MOST companies simply retained features from the 2005-2010 Style UCA....while we were engineering our parts to be specific for the 2011+ UCA System Change.
The Steeda UCA MOUNT appears to still retain the 14mm through bolt, so, a 2011+ UCA will not work. A 2011+ UCA WILL work on our 2011+ Specific UCA Mount.
I also suspect this is why Mr. Fair had issues with his previous design UCA Systems. He claimed the factory '11 has a 14mm bolt, IIRC, in his blog....but that is simply not true. Somehow he ran into some incompatibility issues with the components he chose to run - and I feel his opinion of aftermarket pieces is slightly flawed due to this - as our parts fit like a glove.
Hope that helps!
:beerdrink:
Hope that helps!
:beerdrink:
I'm not sure what my power levels were, but I had a lot I hard launches in that car in the first two weeks. I ended up replacing them with billet steeda ones and haven't had an issue yet. The j&m bushing was so destroyed that steeda asked if they could keep the failed bushing for comparison.
The j&m lca looks nice, and they do have a lifetime warranty on the bushings, which is why I got them. But I couldn't wait around for another bushing because it was pretty dangerous driving my car like that.
I didn't contact them because my car was pulling so hard to the right that I drove it to steeda the same day to get it fixed. I actually took it to them because I thought I needed an alignment and they discovered the lca bushing.
It could be. I used all of the supplied grease, but maybe it wasn't enough.
what kind of power is your pony making?
