2013 Mirrors w/Puddle Lamps Installed on an 06
Old May 6, 2012 | 04:17 PM
sscobra's Avatar
Well, finally got around to doing the install. Love it! Works with the keyless entry. I tied them into the interior lights circuit.
Install:
2013 mirror has 7 wire connector
05-12 mirror has 3 wire connector
2013 Wire Colors:
Black, Green/Purple - Heating Elements
Black/White, Gray - Puddle Lamp
Yellow, Red, Blue - Mirror Motor
05-11 Wire Colors:
Conversion: 1 Side
1. Unpin the the wires from the 2013 mirrors.
2. Remove mirror glass from mirror
3. Pull mirror harness back through housing to gain extra access to wires
4. Remove heating element wires (I'm not worried about heated mirrors)
5. Clip pins off wires and install bullet connectors, then shrink tube (5 - total, if not hooking up heating elements)
6. Remove door panel and mirror from car
7. Remove A-pillar trim from car
8. Remove map light housing from car
9. Remove factory mirror plug from wire harness
10. Install 3 bullet connectors and shrink tube
11. Using 16-18 gauge wire, run two wires from mirror connector location into door, through door grommet, run wire up A-pillar and under headliner to map light housing area
12. Install 2 bullet connectors to new wires on end where mirror is located
13. Use 2 scotch lock connectors and connect the 2 new wires to the black and white wires of the interior map bulbs. (Gray wire from mirror to Black wire at map light, Black/White wire from mirror to White wire at map light)
*There seems to be a resistor or something inline with the Gray wire going to the puddle lamp. If you reverse the wire hook up from above, the light will not shine.
14. Install 2013 mirror
15. Connect all connectors (obviously, red, yellow and blue go together, they are the same on all cars)
16. Replace all panels that were removed
Repeat steps for opposite side mirror
This is just a quick and brief description of the install. I will try to add more pics soon. Let me know if you have any questions.
Attached Thumbnails 2013 Mirrors w/Puddle Lamps Installed on an 06-5612-020.jpg   2013 Mirrors w/Puddle Lamps Installed on an 06-5612-019.jpg   2013 Mirrors w/Puddle Lamps Installed on an 06-5612-017.jpg   2013 Mirrors w/Puddle Lamps Installed on an 06-5612-018.jpg
Old May 6, 2012 | 04:32 PM
whokilledkaji's Avatar
Was it difficult to do the wiring?
Also, where did you get the mirrors?
Old May 6, 2012 | 04:35 PM
sscobra's Avatar
They weren't too terrible to wire. Hardest part was running the wires through the door grommet. I got them from Ford.
Old May 6, 2012 | 04:55 PM
youngstang90's Avatar
What was cost?
Old May 6, 2012 | 05:05 PM
3.73-11's Avatar
fyi if you look at your 2010+mirrors you can see the section that snaps out for the pony projectors to snap into under the mirrors.
If someone can find the part number from ford and you know how to do wiring you can easily ad these to your 2010+mustang.
As soon as we find out the part numbers we'll be doing it to possibly both of my buddies 2011 mustangs.
Old May 6, 2012 | 09:50 PM
Keep us posted! I'd be interested in doing this too!!!
Old May 6, 2012 | 11:50 PM
msqr's Avatar
Could you please share the part number(s) you ordered from Ford and the cost?
Old May 7, 2012 | 12:23 AM
HizliBullet's Avatar
+1
i'd like to know that too.
Old May 7, 2012 | 12:36 AM
2 Go Snake's Avatar
Cool
This is really BIG ! May just become the most popular Mustang mod.
Old May 7, 2012 | 12:42 AM
silversky545's Avatar
I feel stupid... Wtf are y'all taking about??? Is there a led on the bottom side of the mirror that projects a horse in the ground? If so that is flipping sweet! And I'm going to do this on my agent 47s if that's possible :-/
Old May 7, 2012 | 01:20 AM
Pete07GT's Avatar
https://themustangsource.com/f726/pi...mirror-508040/
Old May 7, 2012 | 01:55 AM
So? They are about $250.00 for each side?
Does that include new painted skull caps?
Old May 7, 2012 | 05:38 AM
Bucko's Avatar
$250.00 per side to shine a running horse on the ground....what's this world coming to? And this may be the most popular Mustang mod?!?!
Old May 7, 2012 | 06:32 AM
Boomer's Avatar
If you want heated glass.
From the other thread its $57 per light.
Still not cheap, but a cool mod if you can do it.
Old May 7, 2012 | 07:55 AM
wheelman's Avatar
Nice! Good job.
Old May 7, 2012 | 08:12 AM
Bucko's Avatar
Heated mirrors would be a good thing then for those in the cold north. I can see that as a justification then. My bad.
A savings for me though for being fortunate in living in the south. My wifes car has heated seats too, although that's a waste for the south; that, and I can park my bottom side on them for a few minutes and warm them for her.....
Old May 7, 2012 | 09:00 AM
Boomer's Avatar
Don't get me wrong, I'd like heated mirrors.
My parents have it on their last 2 fusions..great in the winter.
I wouldn't pay for it on my mustang though, it's stored.
Old May 7, 2012 | 09:25 AM
bones302's Avatar
well, this is the push I needed to get this project going. Just ordered a set of puddle lamps.
going to add led blinkers as well and the spotter glass (I have a '10 so didn't come with the spotter glass)
Old May 7, 2012 | 09:46 AM
carfreak666's Avatar
That looks nice!!!
Old May 7, 2012 | 10:28 AM
kylerohde's Avatar
Can't wait for someone to do pics + step by step instructions for idiots like me to do this mod - I want 'em!
