2011 GT/CS fog lights
I recently installed the GT/CS front valence with foglights and was wondering if there is a way to adjust them? I didnt really look when i installed it all so i would like to know before i go take all the crap off the bottom to look. Thanks
Its really easy to adjust actually... Just like your headlights. After you remove your lower plastic thingy (that's the technical term) just turn those screws to adjust the height. I've found this to be easiest with ramps because you can just back the car off of the ramps to see if you like the height instead of using floor jacks
