2011 GT/CS fog lights
Old Dec 26, 2012 | 05:37 PM
5Dot0H's Avatar
I recently installed the GT/CS front valence with foglights and was wondering if there is a way to adjust them? I didnt really look when i installed it all so i would like to know before i go take all the crap off the bottom to look. Thanks
Old Dec 26, 2012 | 07:26 PM
Siber Express's Avatar
There is a Screw on the bottom of the light, PITA to adjust though, so make sure you like it before you reassemble the underside of the car.
Old Dec 27, 2012 | 08:53 AM
TORMENTOR's Avatar
I installed the GT/CS Lower Fascia on my 2012 and didnt like the way the fogs were aimed. I never got around to adjusting them before I had my accident
Old Dec 28, 2012 | 07:48 AM
TheDivaDanielle's Avatar
First thing I did after I converted to the GT/CS fogs on my '13 was reaim them. Like three times, till I was happy with where they were shining.
Old Dec 29, 2012 | 04:50 PM
G Wrecks's Avatar
Its really easy to adjust actually... Just like your headlights. After you remove your lower plastic thingy (that's the technical term) just turn those screws to adjust the height. I've found this to be easiest with ramps because you can just back the car off of the ramps to see if you like the height instead of using floor jacks
JT_Kwik
Nov 29, 2022 01:45 PM
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
DEPUTY62
Sep 12, 2015 11:12 AM
