SVT Brembos w/ PP Wheels?
Old Aug 26, 2012 | 06:31 PM
zbrewha863's Avatar
I have a 2012 V6 with the Performance Package, which includes 19" wheels, but I have no idea about the offset & such of the wheels. Will the SVT Brembo kit fit behind those wheels?
Old Aug 26, 2012 | 06:52 PM
Ltngdrvr's Avatar
Nope, won't fit by quite a ways.
Old Aug 26, 2012 | 07:52 PM
cpotts13's Avatar
Well crap, sorry to recomendation something that wouldn't fit anyways!
Old Aug 27, 2012 | 07:54 PM
zbrewha863's Avatar
Ok thanks, do you know how much? Is it something where I could run spacers and extended studs and get by?
Old Aug 27, 2012 | 08:22 PM
Ltngdrvr's Avatar
About a 1/2 inch I believe.
You could run spacers but I wouldn't suggest it.
If you just want big brakes, Baer makes a 14" rotor upgrade kit that uses the stock calipers.
Old Aug 27, 2012 | 08:39 PM
cpotts13's Avatar
Link!!
Old Aug 27, 2012 | 10:33 PM
zbrewha863's Avatar
1/2" seems excessive, unless those PP wheels just have horrible offsets/backspacing. A 25mm spacer is completely safe, and would give plenty of clearance, but I'd definitely like to know the specifics before I just start ordering crazy parts Do you have a link or anything like cpotts suggested?
I don't want to go with bigger rotors, that puts me at the same disadvantage as if I had upgraded the entire braking system, so I need to get my penalty's worth of performance here
Old Aug 28, 2012 | 11:15 AM
You realize 25mm is about 1" right? 1/2" spacer wouldn't be bad at all. On my SN95, I've been running 1" in rear and .25" in front for years. Driven HARD on bumpy mountain backroads/dragstrip. Just get high quality spacers from Maximum Motorsports.
Old Aug 28, 2012 | 07:02 PM
Ltngdrvr's Avatar
No link, try GOOGLE.
I don't understand though, you don't want bigger rotors? The brembos have 14" rotors so you are looking for bigger rotors...
And it's not necessarily the offset or backspacing that makes the clearance for the big brakes, it's the shape of the spokes, ones made for big brakes are curved out on the back for the clearance.
Old Aug 28, 2012 | 08:54 PM
cpotts13's Avatar
http://www.cjponyparts.com/baer-fron...5-2012/p/BR36/
bit expensive.
Old Aug 29, 2012 | 06:10 AM
Ltngdrvr's Avatar
Originally Posted by cpotts13
I've seen those kits for less than $600 before, just have to search around some.
Old Aug 29, 2012 | 08:07 AM
zbrewha863's Avatar
No need for the attitude. I tried Google, nothing out there on the offset or fitting a BBK on those wheels. All I could find was the approximate weight of the wheels, which doesn't really help me at all.
First of all, the offset and backspacing has a huge amount to do with whether the brake kit will fit or not. Those two things determine how far the brake calipers can come out before they contact the wheel. The shape of the spokes does help, but you don't need curved spokes to fit a big brake kit.
Also, I guess I did a poor job of explaining racing class rules -- here is the deal with upgrading the rotors. The "beginner-oriented" street tire classes will allow you to change out your pads and rotors, but you must maintain the same rotor diameter as stock. So you could use stock-sized slotted/drilled rotors if you want to, but that's it. If I go with bigger rotors, I immediately get bumped up into a much faster class where full big brake kits are allowed. So I'm effectively penalized for only going with larger rotors, because I'm competing against cars with big brake kits.
Old Aug 29, 2012 | 10:37 AM
If you use the OEM Brembo calipers and 14" rotors, will the track inspectors know? I have no way of verifying this, but I would almost bet that setup with a 0.5" spacer would be fine with your stock wheels. Look around on the forum to see if you have anyone with the BBP on their GT near you. You could pick up a set of the spacers and try it out. You won't be able to upgrade the calipers and use the stock rotor size....
Old Aug 29, 2012 | 11:00 AM
zbrewha863's Avatar
I do realize that, my post was confusing. I was saying that it seems like needing an additional 1/2" for clearance is excessive on a 19" wheel. I'm not worried about running a 20-25mm spacer on that wheel.
(1) I'm sure they will know, because you can't get Brembos on the V6.
(2) I realize I will have to upgrade the rotors at the same time.... What I was saying is that if I'm upgrading the rotors, I pretty much have to upgrade the calipers at the same time or else I'm being judged as if I were running the larger calipers anyway.
Old Aug 29, 2012 | 11:04 AM
I see. Well maybe you could get away with the OEM Brembos, being that they ARE available on the GT?
You might even be able to get away with a 0.25" spacer.
However, you'd be surprised how switching to slotted rotors/better pads/stainless lines/better fluid can make a huge difference, and keep you within your class.
Old Aug 29, 2012 | 11:31 AM
zbrewha863's Avatar
Yeah that's a good call. Another member on here suggested going with the SVT Brembos, so that's why I was looking into it. I have the V6 Performance Package, which comes with the GT's brakes, so I think with some better pads/lines/fluid it can be pretty competitive.
FromZto5
75
Oct 5, 2015 02:27 PM
M3hunter
Sep 10, 2015 09:26 AM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 5, 2015 11:50 PM
