Spare tire vs. tire inflator on 2012 V6?
#41
The 17" wheel will fit fine on the Mustang with the Pony Package, but don't drive very far on the spare wheel if you mount it on the rear. The limited slip differential is under a lot of stress because of the different diameters of the wheels/tires. I have the 17" spare with the MCA package. I plan to mount the spare on the front and move a front tire to the rear if I have a flat tire on the rear.
#42
Originally Posted by traxiii
Why would you do that? The rear has a lot less to do, that is, turning with the spare up front could be hazardous at even low speeds. Also if you have 14" brake rotors (Brembo, etc.) it might not clear anyways.
#43
I went to order the 17” x 5” mini steel spare wheel with tire kit for my 2012 base V6, part number: CR3Z-1K007-A. My Ford Dealer says they are currently available for $277.14, looks like the price is going up!
#44
Originally Posted by psulefty View Post
Deysha:
I have a 2012 V6 3.7L 6spd Manual with the performance package, meaning 250/40R19 tires, appropriate wheels, and that horrible temporary mobility kit -- is there a spare I can buy that is operationally safe and fits in the spare tire well? What size, what wheel and tire, etc.
Thank you!
Deysha, I realize that this is an old thread and subject but I don't see the answer to the question, " Does CR3Z-1K007-A fit the 13-14 V6 performance package car? (Comes with the 255/40R19 tires with reference to special brake pads. Available info on difference in brakes on these cars is very sketchy. They are not the Brembo.) I checked with the dealer, their service department, and Ford Motors by email. Nobody seems to know anything.
Thanks for any info you may have to offer.
Tom
Deysha:
Thank you!
Hello guys,
I have confirmed this Spare Kit is for all 2011-2012MY Mustangs, whether it came with 17” or 18” wheels.
Deysha
Deysha
Tom
#46
Deysha:
Thank you!
Tom
Deysha:
Thank you!
Tom
#47
Hello guys,
Deysha
Deysha
#48
This kit is for 11s and 12s only. You can have your dealer find a spare that’s optioned for your vehicle. You will need to provide them with your VIN so they can find an exact fit.
Deysha
#49
#50
Do you have the Brembos?
#52
The subject kit at least now shows fitment for 12, 13 and 14 model year Mustang, but no info about performance packages. Click on "View compatible vehicles."
http://accessories.ford.com/kit-wheel-10136.html
I had a similar experience with the dealer, but I had pretty low expectations because I was trying to price the jack and tools that my GT didn't come with (Track Pack). I knew I was in trouble when he asked for the VIN and then told me the car wasn't equipped with these tools (no kidding).
#53
I bought a plug kit and scissor jack from Autozone then put both items in a soft sided Craftsman tool bag with some pliers and a breaker bar and socket. As long as the puncture isn't in the sidewall a plug will work fine and can be done on the side of the road. Our insurance policy covers roadside assistance if we shred a tire. I kept the tire mobility kit in place because I will need the compressor if I have a flat.
Not saying that a spare wouldn't be better but in 32 years of driving I have had to use a spare tire 3 times. For perspective, my 85 Mustang GT has its original spare tire and it has never been on the ground.
Regarding what spare to use, there are two considerations.
First is the diameter of the of the tire itself. Our cars are based around a 27-27.6" diameter tire and it doesn't matter if your car came with 17s, 18s or 19s. Don't believe me, go to the Tirerack and look up the stock tire sizes for the 17, 18, and 19 wheels that came on our cars. The outer diameter of the tires will fall within a range from 27-27.6"
The second issue is the size of the front brakes on your car. V6 mustangs have 12.4" front brakes and 17" wheels will fit over them. Mustang GTs have 13.2" front brakes and an 18" wheel at a minimum is required. If you installed 14" Brembos I believe you are out of luck for a spare unless a spare tire option is available for the Boss 302 or a Brembo package GT.
#54
I bought a plug kit and scissor jack from Autozone then put both items in a soft sided Craftsman tool bag with some pliers and a breaker bar and socket. As long as the puncture isn't in the sidewall a plug will work fine and can be done on the side of the road. Our insurance policy covers roadside assistance if we shred a tire. I kept the tire mobility kit in place because I will need the compressor if I have a flat. Not saying that a spare wouldn't be better but in 32 years of driving I have to use a spare tire 3 times. For perspective, my 85 Mustang GT has its original spare tire and it has never been on the ground. Regarding what spare to use, there are two considerations. First is the diameter of the of the tire itself. Our cars are based around a 27-27.6" diameter tire and it doesn't matter if your car came with 17s, 18s or 19s. Don't believe me, go to the Tirerack and look up the stock tire sizes for the 17, 18, and 19 wheels that came on our cars. The outer diameter of the tires will fall within a range from 27-27.6" The second issue is the size of the front brakes on your car. V6 mustangs have 12.4" front brakes and 17" wheels will fit over them. Mustang GTs have 13.2" front brakes and an 18" wheel at a minimum is required. If you installed 14" Brembos I believe you are out of luck for a spare unless a spare tire option is available for the Boss 302 or a Brembo package GT.
#55
1 Post
Get it!
We had a blowout in the 6'er last fall on the PA Turnpike @ 75+ mph.. The sidewall on the tire was destroyed and if I had not put the spare, jack, etc from my 08 into her 6'er we would of been stuck waiting on a tow. As it was it was a very, very long ride home, in the rain, at 50 mph, with the 4ways on.
#56
I plan on getting CAA (AAA equivalent) when my coverage expires through Ford. i have NEVER waited more than 30-45 minutes for service (unless in the winter season)
best 80 bucks a year anyone could spend.
JonathonK
9/29/15 09:27 AM
9/8/15 10:45 AM
