removed muffler, hearing a knocking sound
so today I removed my muffler and when I drive and hit like a little bump or a part of the road that's uneven I hear a knocking sound that's coming from the exhaust area. how can I fix this?
Put the muffler back on? ![Dunno](https://themustangsource.com/forums/images/smilies/dunno.gif)
What you're hearing is likely the now un-secured pipe bouncing around like a tuning fork under the car, hitting the road, or the car.
Of course, I'm assuming that by 'took the muffler off the car' you actually mean exactly that, and not '...and then I put on axle-back straight pipes in place of the muffler', in which case my answer isn't as applicable.
In the latter case, it's probably a bad hanger setup or you left something loose.
Maybe you need to take it to a muffler shop and have it all checked up and secured.
Its the passenger side pipe bangin on your strut bar i had the exact same issue (maybe it was driver side idk)
I just wrapped and taped a couple microfiber towels (if they get wet youll have to wrap another one) and noore knock.
