Mustang 3.5L Ecoboost engine swap
Old Feb 14, 2016 | 07:26 AM
  #921
Ecostang's Avatar
Should do the mount too...
I thought a lot about it but wasn't sure it matters? Here's the logic behind my thinking. There's many upper control arms sold and only a couple of them offer the bracket, as far as I know no one sells just the bracket. If the bracket was a problem it seems like anyone selling an arm would include the bracket? Also I think if you only changed the upper arms and not the lower arms it would be more of an issue since your rear end would still be dancing around side to side. With the rearend pinned down with more solid busing it seems like the only force applied to it would be back and forth which I think it's totally fine for, I would worry about the side to side strength though. Has there been any issues with the factory brackets?
I should have welded some supports on it while I had it out of the car, that would have been pretty simple and effective.
Btw this was a total pita to change that arm, you have to remove the bracket to get the control arm bolt out. The bolts for the bracket were the toughest bolts I've removed from the car yet. It required a heavy duty impact turned all the way up and it barely got out the top bolt, it fought me the whole way! First I tried a ratchet and a cheater bar and nearly ruined the socket, had to go buy a heavy duty socket.
Old Feb 14, 2016 | 10:16 AM
  #922
Yeah that upper is a bish! I paid to have it done by a buddy/shop. He tracks his MR2 and is very familiar with all the adjustable suspension bits, so I trusted him. Even he said he had a 3 ft breaker bar and a pipe on top of it to break that bolt loose. I think it's almost 200 ft/lb from the factory? Anyhow, I see your reasoning with not doing the bracket. I bought them as a package though, so didn't feel a reason to not use it, since you have to take it out anyways.
Old Feb 14, 2016 | 01:37 PM
  #923
Ecostang's Avatar
Finished the trunk wiring and cleaned it up
Old Feb 14, 2016 | 01:42 PM
  #924
Ecostang's Avatar
Got the key wired so it cranks the car, before we were jumping the starter relay. I got the seats installed too.
Car cranks but doesn't start, Lexiion think he knows why and when he makes it over I would assume we can start it and go for a drive!
Old Feb 14, 2016 | 03:42 PM
  #925
Gabe's Avatar
That was 2 hours ago.
Drive it yet????
Old Feb 14, 2016 | 03:45 PM
  #926
LEXiiON's Avatar
Drive it yet????
Nope. Haven't been over there yet
Old Feb 14, 2016 | 04:40 PM
  #927
Gabe's Avatar
How about now?
Old Feb 14, 2016 | 05:07 PM
  #928
lowblustang00's Avatar
Cause it's funny.
I'm wanting a video of this first drive too.
Old Feb 14, 2016 | 05:31 PM
  #929
LEXiiON's Avatar
We drove... Video coming soon.
LEXiiON
Old Feb 14, 2016 | 05:50 PM
  #930
Ecostang's Avatar
It's sweeeeet! Feels strong but I didn't get on it to much yet. A few videos coming.
Old Feb 14, 2016 | 05:59 PM
  #931
LEXiiON's Avatar
Old Feb 14, 2016 | 06:15 PM
  #932
Ecostang's Avatar
you said to drive easy until we get the tune! Haha
Old Feb 14, 2016 | 06:44 PM
  #933
Ecostang's Avatar
Old Feb 14, 2016 | 06:56 PM
  #934
walt460's Avatar
Congrats! Can't wait for more.... tune time soon?
Walt
Old Feb 14, 2016 | 06:58 PM
  #935
Ecostang's Avatar
Walt
Yes, we will get the tune uploaded and go for another test drive. After that we need to take the dash back out again to finish the wiring.
Old Feb 14, 2016 | 07:16 PM
  #936
Niiiiiiice!!!!!
Old Feb 14, 2016 | 07:20 PM
  #937
Ecostang's Avatar
First drive!
Old Feb 14, 2016 | 07:41 PM
  #938
zackmd1's Avatar
Loving the progress!!! Making me wish I had the money to do something like this....
On a related note: Whats up with the speedo? Almost looks like it is sensing throttle position.
Old Feb 14, 2016 | 07:55 PM
  #939
Ecostang's Avatar
Thank you!
The speedo is currently possessed, we think it might be reading boost?
Old Feb 14, 2016 | 07:57 PM
  #940
LEXiiON's Avatar
Thank you!
There are a couple of things wrong with the cluster. We probably have to add ZeroAviation's black box to fix that.
LEXiiON
