Help for speedometer correction after gear change without tune
Old Oct 18, 2022 | 03:11 PM
  #81
05stangkc's Avatar
At 65MPH in 5th gear with stock 3:55 gears...My speedo hovers between 2000-2200 RPM with 26.7" diameter 275/40/18" Firestone Firehawk Indy 500 tires on 2007-09 Shelby GT500 18x9.5" wheels on all 4 corners.
You Have a .68 Overdrive and The Chart Puts You Right at 2000 Rpm at 65. I'm good With that!
Thanks Rocky!
KC
Old Oct 18, 2022 | 03:14 PM
  #82
m05fastbackGT's Avatar
Thanks Rocky!
KC
At your service Kevin!
Old Oct 18, 2022 | 04:41 PM
  #83
Siber Express's Avatar
I am like 79 MPH at 2000 in my F150 with 32 inch tires and 3.55's but I still only get 16 on the highway with a tailwind
Old Oct 18, 2022 | 08:54 PM
  #84
With running 32 inch tires, 3:55 gear ratio and Boss 6.2... 16 MPG highway is actually pretty decent IMO
Old Dec 19, 2022 | 03:08 PM
  #85
05stangkc's Avatar
@CharlieH
Did This Mystery Ever Get Solved!
Inquiring Minds Want to Know.
Can I Get Some Likes on That????
KC
Old Dec 19, 2022 | 03:52 PM
  #86
Bert's Avatar
obliged
Old Dec 19, 2022 | 04:56 PM
  #87
GRUDD61's Avatar
I use Forscan and a vLinker FS adapter that connects to obd2 port. They recommend another one also (OBDlink EX) but it cannot talk on 18V pin 13 which is required for changing those types of settings (axle ratio, tire sizes,,etc...) I have been using vLinker FS to update many modules with Ford's current calibrations, since I had not updated any firmwares since buying the car in 2012. For example, the IPC module has an update that fixes the "can't reset oil life" after 60k on odometer issue.
Take several days and read thru forscan forum. They basically help u thru each step.
Old Dec 20, 2022 | 06:23 AM
  #88
Bert's Avatar
Originally Posted by GRUDD61
...Take several days and read thru forscan forum. They basically help u thru each step.
I think that is the problem: most people do not have several days to figure out forscan; so they are looking for a quicker and easier way to do some simple things.
Slowv6
Jul 3, 2023 12:13 PM
MagicEyez
Aug 2, 2013 07:23 PM
Kingfish
4.6L GT Modifications
Mar 4, 2011 02:57 PM
alcarames
Sep 9, 2010 07:30 PM
elvism
1994-2004 V-8
Jun 28, 2005 07:03 AM
