Just got my intake and tune combo, have some questions.
Old Aug 29, 2010 | 06:51 AM
alcarames's Avatar
I installed my intake and tune from steeda. While installing the tune I forgot to set the gear ratio so I had to reinstall the tune with the correct gear ratio. I also notice the tach needle bounces around a bit maybe a hundred or so rpm's while at idle. Is this normal for a tune, and is there anything else I need to set like the wheel speed setting etc? Could I have messed something up by installing the tune twice? Any help would be appreciated. Thanks.
Old Aug 29, 2010 | 08:28 AM
Modshack's Avatar
Sounds like you're fine. My idle bounces around a little also. You could always raise the idle speed a bit to settle it down.
Old Aug 29, 2010 | 09:02 AM
alcarames's Avatar
See these are things I thought were all done by the tuning company that writes the custom tune. Are there any other settings that are more or less mandatory like the gear ratios and such. Thanks for your help by the way.
Old Aug 29, 2010 | 09:07 AM
Modshack's Avatar
The "Tune" is done by them, but there are certain parameters you can set to adjust it to your particular set-up.....Octane program, Gears, Idle, max RPM's etc.. Very easy to step through the choices and make the selections. Only takes a few minutes
Old Aug 29, 2010 | 09:26 AM
Ltngdrvr's Avatar
They can and will set all those things in the tune if you ask them to.
Old Aug 29, 2010 | 10:47 AM
alcarames's Avatar
I'll give steeda a call just to confirm with them and make sure I didn't do anything wrong. Thanks for the help guys.
Old Aug 29, 2010 | 11:08 AM
Ltngdrvr's Avatar
You can always reload the stock tune and the do the performance tune over again just to check.
The SCT handheld will tell you if there was an error though.
Old Aug 29, 2010 | 11:41 AM
montreal ponies's Avatar
That's what they did with mine. I didn't touch a thing.
Old Aug 29, 2010 | 11:43 AM
Ask to speak to Jeff, he's the one that lurks from time to time here on this site under the name Steedagus. Also, if you call him up before i do, ask them if they figured out the skip shift thing so we can get a sofware update to get rid of it.
Old Aug 29, 2010 | 12:25 PM
Ltngdrvr's Avatar
All the SCT dealers now have access to the software to eliminate the skip-shift.
Old Aug 29, 2010 | 04:21 PM
MBK's Avatar
MBK
what're your gains?
Old Aug 29, 2010 | 04:38 PM
GJM20115.0's Avatar
Ask to speak to Jeff, he's the one that lurks from time to time her on this site under the name Steedagus. Also, if you call him up before i do, ask them if they figured out the skip shift thing so we can get a sofware update to get rid of it.
I had my tune done at Steeda on Thursday. Gus told me that they have the skip shift resolved and you can now have it in the tune. I have an auto so it didn't apply to me.
Old Aug 29, 2010 | 07:04 PM
That's good news, i'll bring in my SCT this week. Thx
Old Aug 30, 2010 | 07:07 AM
alcarames's Avatar
Okay, called Steeda this morning. Asked for Jeff they said there's no one there by the name of Jeff. Steedagus' name is Gus. They said the unstable idle is not common, I explained the tach slightly rises a hundred or so rpm's and then maybe drops a hundred or so from where it should be. Acording to the person I spoke to they've never experienced this with cars they've driven. They recommended I go back to stock and then start over and go from there. By the way they said Gus is the one who does the tuning for these cars.
Old Aug 30, 2010 | 10:25 AM
SteedaGus's Avatar
Actually, I'm Gus, and I lurk under another name..... wouldnt be lurking if everyone knew who I was... LOL j/k
And yes we now can eliminate skip shift.
And also, I'm not the "tuner" here. I am the National Sales Manager. Although I've been trained at SCT, I am in sales and because of my SCT training and being in the "front lines" so to speak with customer interaction I pretty much end up doing most of the tech support, etc..... So I am well versed and know the tuning software inside and out, but not the guy that normally writes the tunes or does our in house dyno tuning.
I do participate hands on with tuning once in a while. I actually came in Saturday when I was off and helped out to finish a 2006 GT we just installed a Whipple and Steeda Whipple Belt Drive on. But you would typically not find me on the dyno and doing anything like that during the week. Not enough time for that
Old Aug 30, 2010 | 10:31 AM
White2010's Avatar
My idle bounced a little bit when I first switched to 93 but smoothed out in less than a 1/4 tank.
Old Aug 30, 2010 | 10:47 AM
Modshack's Avatar
Email sent!
Old Aug 30, 2010 | 02:50 PM
Modshack's Avatar
Originally Posted by Modshack
Email sent!
Within a few hours of emailing Gus, I got the new updated files emailed to me. I'll be installing in the morning.
Terrific customer support from Gus and Steeda. More in the morning!
Old Sep 1, 2010 | 08:45 PM
alcarames's Avatar
Update, I got an IM from Gus and he says they've been working on smoothing out the idle on the mustang and they've found something that works. They'll be emailing me the file. I was just getting used to it, and my buddy's car who has the brenspeed tune on his also has the same idle. I've gotta say all the good things said on these forums about Steeda's customer support and product quality are true!
Old Sep 2, 2010 | 05:34 AM
RedCandy5.0's Avatar
Just want to thank you guys ordering tunes early for being the guinea pigs and making these tunes perfect for us who wait until the bugs are worked out.
